Clattering from clutch/flywheel area
Robinson
Wed Sep 26, 2007 6:15 pm
Started off as a sort of worn gearbox bearing noise at idle, something rattles occasionally when accelerating too, now it rattles loudly at idle as the car has a rough idle, which is something else to have a look at :|
Any ideas? the clutch works fine and the gearbox is on approx 100k apparently. It's a 318iS engine and box.
I doubt it's the gearbox, what clutch related usually makes these dodgy noises? How long does it usually last once it starts making noise too? I'm doing a track day tomorrow and off to the ring next weekend, luckily i have a few spare cars.
Robinson
Wed Sep 26, 2007 6:19 pm
Just to clarify yes the noise goes away if i depress the clutch pedal ;)
Wed Sep 26, 2007 6:23 pm
the getrag boxes are known to "chatter", something to do with the layshaft bearings I believe. The uneven idle will be making it seem worse.
If it is this, which it sounds like it is, the box will be fine
Robinson
Wed Sep 26, 2007 6:24 pm
Hmmm. Dodgy.
I was all paranoid then :|
Bring on the abuse :D
Dave_M3
Fri Sep 28, 2007 8:05 pm
I'd put my money on it being the release bearing.
Even if it was its only a minor problem that can be done eventually when time permits
My track car is after devloping the same problem
*Edit*
Oops, I spoke too soon. should have waited for the page to load properly :o:
I didn't know the gearbox had rattle problems at all. Learn something new everyday 8)
Theo
Fri Sep 28, 2007 8:11 pm
Another Ringer from Tunbridge Wells eh? :cool:
