318is m30
beefy
hi would a 318is be suitable car for the m30 conversion. I have an m30 just looking for a e30 to put it in. what i would like to know is what running gear would be needed if i bought an 318is
cheers
cheers
SPADGE
Probably one of the best cars to use for a conversion mate as it has the larger front struts and 4 disc brakes etc...to start with as well as sports trim, black headlining etc.
You will need the engine, gearbox, prop and a better/bigger diff as well as the usual rad and mounts.
No different really to converting any e30 to run M30.
Also unlike the M40 powered cars the running gear and engine that you remove will have a decent value for re-sale
beefy
cheers for the info spadge
E30 M30 Mounts £100 pm me for info.
Dave_M3
Looks like there'll be another 318iS killed because of "Bigger is always better" lol
The running gear would be handy for the 318iS touring conversion in the other thread I was reading a few minutes ago
http://www.e30zone.net/modules.php?name ... ic&t=79466
beefy
i have the prop from the 535i will i also need the prop from the 318is i thought i would. Also will i need the rubber engine mounts from the 318is or do i need to get some m20 ones.
maxfield
Have a custom prop, not that expensive. Or go M3 prop.
Not sure about mounts.
beefy
yeah i thought i would be using the diff end of the 318is prop and the gear box end of the 535i prop welded and balanced.
Or is it just a section cut out of the 535i prop and welded back together.
Theo
Think you will need the m20 mounts, the studs pn the m42 mounts are offset, so wont line up with the holes in the metal engine mount.
gareth
that's an interesing point theo, could the 318is mounts be used to shove the M30 over a tad? more (some!) steering column clearance is always a good thing
beefy
will i be needing the 318is prop?
Help please
Help please
Theo
Only reason you'd need the 318is prop is if you are doing a chop and weld job, in which case you will need the rear part of the prop.
I'd try ringing the major BMW breakers across the country for an e30 m3 prop first though.
O/T, any update on the mounts?
beefy
Think i will do the custom job, ric325 had one in durham iirc and was pleased with the service and price as im not far from there think ill be doing that. Main point was is there any difference in 318is prop to 325i prop but obviosly not.
There on the way theo went today have pm'd you the info and tracking numbers.
Theo
Nice one John, got your PM just after that post, thanks for getting them off quickly.
Only difference in 318is/325i props will be the length, so nothing to look out for there.
beefy
no probs.
ok cheers for the info theo.
