what does this light mean
ok this light has started to stay on when driving and i can't remember or find out what it means help????
cheers mate thought it was brake related as i have just done the discs and pads but there is fluid in there so might be sensortrevski wrote:goes out after engine has started. if the lamp comes on during a journey, brake fluid is too low!!! hope this helps
slinky2000
- Location: Ireland - North(Portadown) and South (Limerick)
- Contact:
thats the brake fluid light
from left to right
Handbrake light : Brake wear light : Brake fluid light : ABS light : Battery light : Oil Light
from left to right
the brake wear on mine now comes and goes, and brakes have always been a little spongey but still work good.
whats the best COA?
i've got rear drums front ~260mm discs i believe(stock prefacelift 320i 2door not sport or anything)
is it low pads? when i checked them out when doing front springs they looked to have good life in them, discs didn't seem too pitted or warped(eyball no measuring lol)
according the manual its brake lines? would that just be get some braided hoses for the each corner, or the brake lines under the car? no obvious leaks spotted so far
just ordered braided lines for my other car, maybe i should tell them to chuck me some for this as well?
thanks in advance
whats the best COA?
thanks in advance
smithy318i
Intermittent brake wear light flashing is often caused by a dry joint in the instrument cluster. do a search for 220 ohm procedure.
as for spongey brakes, that could be caused by using dot 5.1 brake fluid, or air bubbles in the system. If your brakes have overheated and started to fade, you might need to replace your brake fluid.
smithy318i
brake fluid in the resevoir is low. nothing at all to do with the pad sensors.alexm3uk wrote:ok this light has started to stay on when driving and i can't remember or find out what it means help????
