**Update**
After a lot of faffing about with different clutches and flywheels it looks like i have finally got the correct setup. The first one i got which is shown on the 1st page had clearence issues with my gearbox because of the timing peg.
We then decided to try the JBR dual mass replacement flywheel as mine was originally fitted with the BMW dual mass replacement flywheel, this was supposed to use the standard clutch. However once Dermott delivered it to me in person we found that the clutch fitted ok but the pressure plate didn't fit the flywheel so he then gave me two choise. I could either wait for him to source the correct clutch kit which could potentially mean having to wait for an order from America again or i could upgrade to a flywheel clutch combo from an M50 engined car that people have used in the past, which he had in stock. So i went for the no brainer 2nd option.
I have this morning just got the new flywheel and clutch and given it a quick check and there are no clearence issues in the grearbox so all should be well now.
I cannot speak highly enough of Dermott at Power4Peanuts, he has spent a lot of time trying to work out what had gone wrong and to his own exspense has order numerous parts to try and help me. The confusion stemed from the fact he had only ever dealt with people wanting to upgrade their clutch at the same time as doing the flywheel so he had only ever used the kit i have now got. I hadn't only asked for a lightened flywheel to use the original clutch which made it tricky because the Americans only have dual mass flywheels whereas we only tend to have single mass ones. He does now have 2 dual mass replacement flywheels in stock and will be sourcing the correct cltuch for them so if anyone is interested they will be available and will probably be lighter than the one i have got now.
Here's some pics
