keeping pillars black?
Cloggy Saint
touringandy
would be good to find an answer on this because av tried a few products on these with bad results
most absorb leaving dull marks or finger prints an back 2 black gels leave residue ie grease marks...............
you wish
siddiqi1
- BFG Zone Contributor
a friend of mine tried black kiwi shoe polish and got very good results on his mk3 gti arches.
Now whether this would work on the E30 i am not sure, a suggestion though
I suffer from this problem too, jsut bought some "back to black gel" see how they comes up?!!
Regards
Saboor
Regards
Saboor
Cloggy Saint
I've heard about people bringing plastic arches and bumper trims back to black by using a heat gun on them. Wierd or what.
Kos
i used a polishing compound and they come up nice, G10 by fareclea (sp) and then some autoglym super resin polish keeps it black for a bit !
maxfield
Works a treatE30BeemerLad wrote:I've heard about people bringing plastic arches and bumper trims back to black by using a heat gun on them. Wierd or what.
Cloggy Saint
Kos
correct they are metal. try using a polish which you have lying around. an abrasive one normaly works well and removes any crap thats causing the surface to discolourdatourer wrote:I heard the heat gun method, but doesn't that only work on the softer plastics? The pillar covers are much harder. In fact, aren't they metal? I'm sure I have some rust on one of mine.
Cloggy Saint
Kos
yea, give it a go mate.datourer wrote:T-cut?
Cloggy Saint
Kos
indeed !!datourer wrote:Cheers, and god help anyone that leans on it when i'm done
i'm due a trip to the dam, i'll come a find it just to lean on it when i'm hammered ! LoL
harry_p
yep, i just polished mine up with some mild abrasive bodywork polish i had laying around, still faded after a while but looked nice and glossy for longer than any blackening gell type products i've used before have done.
cheers,
harry
harry
E30Mark
Mop & polish, it's just oxidised paint that need removing...
PM for details
PM for details
touringandy
to use kiwi is a cheap version of bak to black for bumpers mate diff type of coating altogether on door pillars kiwi is good on bumper inserts just dont rub past them lol good suggestion though its an old secret of mine wen valeting to bring back black plastic properlysiddiqi1 wrote:a friend of mine tried black kiwi shoe polish and got very good results on his mk3 gti arches.
Regards
Saboor
you wish
Cotty
- Hartge Crew
I have used Meguires Gold Class Trim Detailer on mine and it works very well. I know its painted and not plastic but it works for me and brings up the door handles which are also painted
BMracing
I used t cut on mine and then some good polish (meguiars tech wax, the same as I use on the rest of my paintwork) and the came up very nicely. Had to work pretty hard with the t cut though, probably would have been better off with G10.
Max
dom-1984-320i
SNAP! works a treat and lasts a while too. give it a couple of coats and make sure its dry in between. 7 quid well spent if you ask meCotty wrote:I have used Meguires Gold Class Trim Detailer on mine and it works very well. I know its painted and not plastic but it works for me and brings up the door handles which are also painted
M20B25 actually
DavieP
I've had to do mine since they become quite greyish. I've got some black T Cut colour restorer (Car Plan) which I had for a previous car and give them a good work out with that. I then finished with a coat of Car Plan Black Trim Wax. I first did this in April '06 and it lasted until May this year. Although they didn't really need it, I gave the pillars another coat of just the trim wax today to 'top up' the sheen and see them through the winter. My door handles aren't as bad and just need an occasional lick of trim wax to remove any smudges. The black rubber insert in the boot spoiler also gets an occasional polish with trim wax, which keeps it looking neat for 6 months or so.
siddiqi1
I agree, tis cheap, havent even tried it myself, bit scared to tbh.........but good old polish i think should do the trick!!!siddiqi1 wrote:
Regards
Saboor
Saboor
abelai
If you really want them looking like new and you've replaced everything else on the car then they are not that expensive from bmw £70ish for all 4
If I can't fix it I'll f**k it up so bad nobody can!!
touringandy
all 4, which 4, does this include the door surrounds ie the bits that go right around and along the bottom of the winows , rear part of the touring window sections, theres more than 4 just on a saloon
you wish
abelai
Thats the main upright sections on the doors and b-pillars
abelai
Have a look here
http://www.realoem.com/bmw/showparts.do ... g=51&fg=20
It would get expensive if you replaced all of them
Cloggy Saint
Kos
cool !!
touringandy
wasnt trying to sound funny there thought it may come all complete would be very expensive i imagine lolabelai wrote:Thats the main upright sections on the doors and b-pillars
you wish
hennabm
I'll second that. I have tried Autoglym bumper care, polish, Meguiars NXT wax but the best I have found so far is the trim detailer.Cotty wrote:I have used Meguires Gold Class Trim Detailer on mine and it works very well. I know its painted and not plastic but it works for me and brings up the door handles which are also painted
The black bits are just covers that go over the main door frame and the window frame.
