wiring up for the amp
johnono
Post Tue May 17, 2005 1:50 am
i have to run a live for the amp but i dont know the best way into the car with the minimum of damage or fussin about
also where is a nice easy earthing point in the back? im putting in a 1000w amp, with a 600w 15" tube and a set of 180w components that i have already put in but have no oomph .. plus the standard gear but i wont be adding them into the system
getting the gear tomorow, cheap and cheerful :wink:
smithy318i
Post Tue May 17, 2005 8:46 am
Run the wires straight down the middle of the car.
under the back seat under the center console. It's a lot easier than removing the door trims/ kick panel/carpet/ door pillar covers etc.
johnono
Post Tue May 17, 2005 9:09 am
cheers smithy! :thumb:
but how do i get the amp live into the cabin?
TOURINGDADDY
Post Tue May 17, 2005 9:14 am
your best bet is follow the loom or find ur self a blank rubber gromet
all depending on what gague cable ur usin :?
smithy318i
Post Tue May 17, 2005 9:18 am
There is a big square rubber grommet behind the back seat (on the passenger side.
TOURINGDADDY
Post Tue May 17, 2005 9:21 am
thats the puppy.... thats a weeeeeeee bit :lol:
Andy_magic
Post Thu May 19, 2005 10:16 am
On a RHD car with the battery under the bonnet there is a big grommet next to the battery.
I ran my +ve supply through this and down the drivers side into the boot.
I ran the RCA signal cables down the other side of the car. It's best to keep the power and audio signal leads apart. It's worth the extra effort.
All the wires can be tucked away neatly using the BMW tie downs for the existing loom. It wont look like theres a dead snake under the carpet either.
johnono
Post Fri May 20, 2005 12:54 am
top toppers andy and smithy and tourindaddy!
i got the gear, and the cables
20mm live with inline 60amp fuse
rca with remote line attatched
earth cable 20mm
the sub
and the amp
so im going for it on sunday, if all goes well
cant wait, i havnt heard loud music since 1993
johnono
Post Sun May 22, 2005 9:55 am
sorry to bump this one up again :stupid: :roll:
i am still trying to feed the live cable into the bulkhead...
iԚ´ve found the rubber gromet next to the battery (in the bonnet end) but it doesnt look like it wants to go through there :x
is there any other "easy" accsess points to get the cable through? got it all here staring at me :(
Borderbmw
Post Sun May 22, 2005 10:19 am
You might be able to get it through if you're careful and use a little bit of lubrication,it should slide through with a gentle bit of pressure.
TOURINGDADDY
Post Sun May 22, 2005 10:26 am
ITS PROB HARD UP AGAINST THE SOUND PROUFIN TOULL NEED A FRECKION BIG TORCH AND ALOT OF FOWL MOUTH TO GET IT THROUGH :lol: :lol: :lol:
Andy_magic
Post Sun May 22, 2005 10:32 am
I ran my supply cable through that grommet in the bulkhead, I pierced it and then opened the hole up with a couple of screw drivers.
Plenty of lubrication is the key to success - :lol:
It was a bit of a mission and took me about 10 minutes
johnono
Post Sun May 22, 2005 11:49 am
nice one lads :cheers:
iԚ´ll get back to it
nav786
Post Sun May 22, 2005 12:43 pm
you can feed it threw passenger side too. there is already some wires running thre a hole on that side and there is enough space for 1 more. it will come the just behind the glovebox.
FOR SALE
SONY PSP'S £100
johnono
Post Sun May 22, 2005 11:46 pm
cheers nav mate! :cool:
i got it sorted now though, screwdriver from inside so i could see light through the grommet, then i knew i had it :wink:
cable is in and as far as the back seats, but ive got a tourer so itll be nice and easy to sort this little lot :banana:
by tomorow lunch i should have it up and runnin.. ull larf when u see how much space this thing takes up :roll: wish id checked it first before i decided to make kitty litter out of the box
johnono
Post Tue May 24, 2005 11:09 pm
yup, its in a running :cool:
big thanks to the lads in question :cheers:
i luv suuuuub
Andy_magic
Post Tue May 24, 2005 11:12 pm
Does it make your mirror vibrate with all that bass
johnono
Post Tue May 24, 2005 11:18 pm
:lol: yea lol, first time i noticed it i went " 8O faaack me"
its loud, thas all i can say. but its not as loud as my mates. the one i have is a 15 " 600w ported sub tube. my mate has a fosgate 12" enclosed sub box and it made my eyebrows twitch when we ran it off the amp
so thats on the list of blags to pull "get mateys sub" :lol: :wink:
Andy_magic
Post Tue May 24, 2005 11:27 pm
:lol:
I seriously rate Rockford stuff, very good quality indeed.
Sealed subs give the best sound quality but less volume than ported subs for a given power rating, for all out volume and really deep bass I've founf band pass enclosures to really make things move. I had a metro turbo about 1993 that I fitted a band pass sub in and it was totally OTT but great fun.
I've gone for clarity with my latest install as I spend lots of time driving my car, still makes everything shake though - I might post a video of the rear view mirror doing its thing.
johnono
Post Tue May 24, 2005 11:36 pm
:cool: i may do that too :D
but true, the rockford is too powerfull, it really was a bit to much at one point, stomach was empty as well :? :lol:
i agree on the whole clarity thing though. after about 2 hours of brain numming incoherant bellows, including the intermittant news reports in pure sub. couldnt understand a thingand almost every tune sounded the same :?
luckily i had a set of component misd and tweeters i put in up front so with a bit of ballancing i can get a reasonable sound. needs a bit of cleaning up though :D
Andy_magic
Post Wed May 25, 2005 12:23 am
I'e set my system up so that the bass & treble are set flat at 0, I've cut any frequencies below 100hz from going to the main speakers and sent only freqencies below 100hz to the sub.
Having said all that, the way a hifi sounds is a very personal thing, just as well these stereos have loads of adjustments, it's more to mess about with.
I hate it when my mates mess about with the levels, they always whack the treble up too high and wind on a shed load of bass...
