is my engine to old to chip?
dom-1984-320i
As above really, 1984 320i, can it be done?
cheers
cheers
M20B25 actually
snoops
- Major Helmet
If its L Jet I don't think it can be done, only motronic systems are chippable afaik
dom-1984-320i
snoops wrote:If its L Jet I don't think it can be done, only motronic systems are chippable afaik
thats what i was thinkin snoops. cheers
M20B25 actually
ShepsEvo3
- Master of go faster
My mothers 1984 320i (A'reg) had Motronic and yes it could be chipped.
Unsure what chips are available, but I know Unichip would work. You would get great gains from it I'm certain as cars from that era never had great maps in them from the factory. Newer cars now are more difficult to extract much noticable extra power from - unless its turbo/supercharged
www.sabre-tuning.co.uk
dom-1984-320i
would this be the case for an L Jet tho? I need more power!!!
M20B25 actually
ed325i
You cant chip the L jetronic ecu.
You can convert to Motronic using the loom/ecu etc from a later car.
dom-1984-320i
really? easy job do you think?ed325i wrote:You cant chip the L jetronic ecu.
M20B25 actually
ed325i
Yes its easy, I done my 323.
dom-1984-320i
whats envlove and what parts would i need? to be honest i would not do it myself cause a would just cock it up, but i would be happy to pay for it to be done.ed325i wrote:Yes its easy, I done my 323.
M20B25 actually
ed325i
Engine loom.
Front crank sensor and bracket.
All the parts to mount the dizzy cap on the end of the cam.
Injectors.
Air flow meter.
I think thats about it.
Injectors.
Air flow meter.
dom-1984-320i
cheers ed, i will look into it. my car is getting lots of love at the moment and looks wise should be how i want it by early november, then its engine time!ed325i wrote:Engine loom.
Injectors.
Air flow meter.
M20B25 actually
bigkev
dom-1984-320i
how much do you think your looking at kev, start to finish? are you doing the work yourself?
M20B25 actually
ShepsEvo3
The Unichip is piggy back, not a chip change of the ECU. It intercepts the signals between engine and ECU.
It should be able to be done with this, but whats been mentioned above MAYBE more economical for your application?
bigkev
No problem that I can see in using the original distributor just to distribute the HT to the appropriate plug. The lower part of the distributor won't be used at all.
