Petrol Smell...
love30
Thu Sep 13, 2007 6:34 pm
Hi Guys, need a bit of advice/help...
I can often smell the aroma of petrol coming from my car...in particular after the car's warmed up or a longish drive...any ideas???
Cheers guys...
jaydub
Thu Sep 13, 2007 6:39 pm
check for exhaust leaks just incase its that coming up through. do you have high fuel consumption? this could indicate a leak, ideally put it up on a ramp or get underneathe and check for drips from the lines and the tank, look for stains aswell. also just eyeball the filter , if not take it to a garage , its not worth getting blown up ! JoN
BMracing
Thu Sep 13, 2007 6:43 pm
Sounds exactly like how mine smelt a few weeks ago. My fuel tank was leaking. May not be this if you say its only after its warmed up, but check your tank out for leaks, pay particular attention to the fuel filler neck on the offside, they are prone to rusting through there. Bit of a tricky job to replace the tank, about 4 hours work :? Not the end of the world though
Max
abelai
Thu Sep 13, 2007 6:55 pm
Check the fuel lines in the engine bay for cracking and weeping. As this could be very dangerous
If I can't fix it I'll f**k it up so bad nobody can!!
kevin316i
Thu Sep 13, 2007 11:34 pm
Check the fuel lines in the engine bay. Had a similar problem recently and found petrol dripping onto the start motor soleniod. Not a good thing...
matttouring
Fri Sep 14, 2007 7:33 am
I have the same problem with my car top tips guys will check these out to
Matt :D
'89 320i Touring 'Switchable' Auto Colour: Dirty
Morat
Fri Sep 14, 2007 12:14 pm
Does it splash a bit of fuel near the rear right wheel when you fill it up to the brim?
Martinaston
Fri Sep 14, 2007 12:24 pm
What engine is it ?
There is NO nucleus.
love30
Fri Sep 14, 2007 12:43 pm
hi guys, thanks for the advice...
It's a 89 325i sport...
it doesnt splash any fuel out when i full tank it...
Fuel consumption seems to be ok i think...get about 175 miles from a full tank of £40
will check the above as advised...
thanks again...
DaveD
E30Zone Wiki Specialist
Fri Sep 14, 2007 12:50 pm
you must have a heavy right foot, I get that from £30...check your fuel lines its a common fault
HairyScreech
Fri Sep 14, 2007 5:02 pm
i just got 320 miles from a tank of £55, thats not normal consumption.
**BANNED**
Fri Sep 14, 2007 6:04 pm
My 2.7 does around 400 miles on a full tank,the 316i touring gives off a petrol smell when full,I am thinking fuel filler pipe for this one,the O/S of the tank has a stain at the rear end.There was a thread by a guy how was offering exchange filler pipes...but er indoors uses it most days.. :cry:
austin360
Sat Sep 15, 2007 12:42 pm
is the car lowered i had a problem wit mine there s a plastic vapour catch can above the driver back wheel witthe clip holding it on broke it left the bottle sitting on the tire which made a hole that caused the smell have a look at that might be it too if nothin leaking
love30
Sat Sep 15, 2007 2:01 pm
Hi guys, just got a fuel line replaced in the engine...was cracking up...will have to see how it goes...
Could a bad fuel line cause rev problems when the car is idle...i.e. reving up & down on its own???
Cheers...
