Engine seized
Andy335Touring
- Contact:
Poor some diesel(sp?) down the spark plug holes, leave it over night to soak, then see if it will turn over with no spark plugs in.
Don't run/fire the engine until you've changed the engine oil as some of the diesel will find it's way past the rings into the sump which your bearings won't like.
This might get it going but it depends how bad it is.
