Can you take seats from 5 or 7 series cars of the era and fit them in an E30 ?
cheers
5,6 series seats fit the E30?
- Pro-detailing
I wanted to put some black Vader leather seats from an E36 m3 into my E30 a while back. I was told they would physically fit but the mounts might be a problem.... I reckon the propper 'armchairs' from the E32 seven might be a problem but the sports seat from an E34 would be great!
Sorry I can't be more help - you need to get to a scrappy and see what the runners/mountings are like - this'll help you to get the one which need the least fettling!
Cheers - Nick
Cheers - Nick
E28 5 series front seats will certainly fit (ie 5 series 81-87) not sure about E24 6 series they should do; 7 series will not. Your best bet are E28 5 series sports seats, all you need to do is take the runners off and put you E30 ones on, as the E28 runner position is wider apart.ssornerrad wrote:Can you take seats from 5 or 7 series cars of the era and fit them in an E30 ?
cheers
An E30 touring, two E28 M5's and an E28 528i.
Ive got e24 635 recaro seats in my touring and they fit as long as you don't have a 2 door (The outside bolt hole uses the bolt for the seatbelt runner.) The front will fit onto the inside stud, but not the outside one. I'm sorting some 1/2 inch bar stock with some holes drilled in it at the right spacing. Then It'll all be safe and sound!
Hi Jam, there's a set of E28 seats on the 5series forum I'm considering but was thinking if they'd fit. If you say so, I reckon I could swap em over. My comfort seats are well tired, but they ARE heated so I'll miss that!!!jam172 wrote:E28 5 series front seats will certainly fit (ie 5 series 81-87) not sure about E24 6 series they should do; 7 series will not. Your best bet are E28 5 series sports seats, all you need to do is take the runners off and put you E30 ones on, as the E28 runner position is wider apart.ssornerrad wrote:Can you take seats from 5 or 7 series cars of the era and fit them in an E30 ?
cheers
E34 525tds - on the way to replace 325i
E30 / 34 spares
E30 / 34 spares
Cloggy Saint
Just remove the heating elements from the comfort seats and put them on the E28 seats.Barnz wrote:jam172 wrote:My comfort seats are well tired, but they ARE heated so I'll miss that!!!ssornerrad wrote:Can you take seats from 5 or 7 series cars of the era and fit them in an E30 ?
cheers
