Rocker tollerance
TheKoose
Sat Sep 08, 2007 11:50 am
Hi guys
Just tryng to adjust my valve clearances but ive come up against something im not sure of. Should there be any play in the rocker itself? Basically i did the first 3 starting from the dissy end, and they were all fine, then i got to the 4th and as i was feeling it it moved a touch, surely you cant adjust the clearence if the rocker has say 0.5 mm of play in it? Are they an easy replacment if this isnt normal?
Mark
kam-325i
Sat Sep 08, 2007 11:57 am
First thing. Which engine ?
TheKoose
Sat Sep 08, 2007 12:01 pm
Oops 325i Sport 1987 :o:
kam-325i
Sat Sep 08, 2007 12:14 pm
There will be some "play" in these engines now. only way to completey remove the play is to renew both the rocker arms and shafts.
Which way is the play ?
Dose the rocker move between the clip, back and forth. or dose it "rotate" on the shaft?
the movement between the clip is normal.
TheKoose
Sat Sep 08, 2007 1:03 pm
It rotates :(
Mark
1987 325i Sport (Tech 1)
Rover 220 GTi Turbo (1 of 500)
kam-325i
Sat Sep 08, 2007 1:18 pm
TheKoose wrote:It rotates :(
That is caused by wear on the rocker shaft and/or the bearing in the rocker arm.
How many miles has the engine done ?
TheKoose
Sat Sep 08, 2007 1:46 pm
182k
Mark
Ant
Retired Team Member
Retired Team Member
Sat Sep 08, 2007 3:59 pm
time for some new ones then dude.
there should be no perceptable play in the rockers on the shafts, leaving them in their current condition often results in one breaking when least convenient.
180K+, defo time for a head rebuild, the bottom end should be sweet stll though :D
TheKoose
Sat Sep 08, 2007 4:52 pm
Feck, ok, can i do it with the head off, only just got it all back together.
Mark
Chris
Sat Sep 08, 2007 6:23 pm
So are the rockers not supposed to 'rock' slightly on the shafts? when the cam lobe is pointing down?
In layman's terms lol :D
HairyScreech
Sat Sep 08, 2007 7:26 pm
yes, thats the valve/rocker cover clearance, i think he means play in the shaft the rockers run on, which is a bad thing.
