hood shelf not locking down
garymillscab
i have an electric hood bt it doesent work and is connected does any1 no how to get the rear shelf to lock into place with hood down. on a 1991 318i
gazza
mine doesnt either the part of the motor that is broken on mine does not pull the hoop down i think if it was working correctly then the final part of folding it pulls the cover down and locks it closed there are a couple of repairs floating around at the moment search the threads
design cab and now 325 touring-
chu346
I've have to push the flap down and put the motor in place, then put a feed to the motor to wind it down.
GuyM
try inserting the allen key into the hood cover motor and turning it clockwise (i think!). this is the one that releases the hood cover motor in an emergency when the elec hood doesn't work allowing you to raise the hood, so it could work in reverse by locking it!....just a thought?
orangecurry
cac289 - good idea but I don't think so - mine is the same, and locking the motor doesn't wind the mechanism - you want the motor to move so that the 'claws' engage
chu346 - what kind of 'feed' do you have? from where to where?
garymillscab
thanks for help bt my hood motor isnt working full stop do i need a new motor and how much?
orangecurry
which motor - the flap or the main hood motor?
The flap motor 'looks' like electric window or maybe windscreen wiper stylee, so if it is that one which is bust take a good look at the serial numbers - BMW would have shared a few items to save money, but the main hood motor is unique and expensive (obviously), and rare 2nd hand
chu346
I take a 12+ and a negative feed and put it direct to the terminals on the flap motor, then if I want to open it i just put the wires on the other way round terminals and it goes the otherway. I've got a couple of amplifiers in my boot, so i just take a feed from them. I would advise if your going to do this to use fairly thick wire if your running all the way from the battery and disconnect them when not in use.orangecurry wrote: chu346 - what kind of 'feed' do you have? from where to where?
