small update, huge turbo...
Colonel Sanders
Le Surrender Monkey.
Location: guernsey.... i mean france munching on garlic and drinking wine with my children.
Post Mon Aug 06, 2007 5:00 pm
just recievied my mls gasket today for my 325 turbo! only ordered it 5 days ago! from vacmotorsport.com, cost me around 150 with postage to me, also got aload of gaskets and such for the inlet ect off zimmerbimmer1, cheers! been messed around so much on ebay lately so just purchased a holset hx35w with 16cm housing, i want to do something different so im gonna take the exhaust strait out the front wing, although i might need some sort of small muffler fitted? idealy i would like to go out in front of the front wheel with the exhaust but not too sure if that will be an issue yet? also for you boost junkys, i want to go external wastegate would this work?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=015
its gonna push the turbo up quite abit so before you say the bonnet will be an issue im takin it off the hinges and using pins to keep it down plus cutting a hole so the turbo can poke out, given the turbo will prob poke out a good few inches but i can live with that, i would like to post some pics up but im pretty crap when it comes to computers but il take a load an see if my mrs can work it out, and il make sure il keep you posted on my progress cos now i have basicly every thing i need exept some small odds an sods im gonna get cracking!
parts i have and fitting:
280mm wilwood brake kit
full koni adjustables 60/40 springs
new wheel bearings
new head with turbo cam
mls stock thickness with 12.9 grade bolts
all new gaskets for inlet exhaust ect
megasquirt and wasted spark
tubular manifold
hx35 16cm
oil feed and return
some other odds and sods i cant remember
havent got an external wastegate as of yet
prob forgoten a load of stuff too, really want it done in time for santa pod to see what she will do as il be running 16 psi, but doubt il make it in time though!!!
Last edited by Colonel Sanders on Wed Sep 05, 2007 3:40 pm, edited 2 times in total.
charlE30
Post Mon Aug 06, 2007 5:10 pm
Sounds like an awsome build dude... 16psi and front exit exhuast :eek:
Wont you need an exhaust to get the car to the pod?
Good luck with it :cool:
BMW F31 335d xdrive
Colonel Sanders
Post Mon Aug 06, 2007 5:51 pm
well i live in guernsey so there aint no mot or emmision laws over here, so if i get stopped they can suck my d!ick!
:twisted:
Colonel Sanders
Post Tue Aug 07, 2007 12:50 am
oh yeah, what engine mounts are you turbo boys runnin?
jar-la
Post Tue Aug 07, 2007 7:11 am
Hi.
Very nice project! :)
One thing: you will race only it, or use on streets? Couse in normal use i dont recommend the exhaust to go out in front of the front wheel. COOL at all, but exh. gases possible "take a journey to driver" due turbulence?
My buddy made it to come out before the rear wheels(E36 328 T). Brutal sound... :D
Colonel Sanders
Post Tue Aug 07, 2007 7:36 am
its for road use. that did play on my mind a bit getting exhaust fumes in my face so il have to look into it a bit more then?
Chris
Post Tue Aug 07, 2007 9:19 pm
Pasenger side wing? winkeye winkeye
Colonel Sanders
Post Tue Aug 07, 2007 9:35 pm
hmmmmmm????
you could be on to something there! dont think it would route through though, il have to check! :twisted:
jmc330i
Post Tue Aug 07, 2007 10:23 pm
rossle wrote:its for road use. that did play on my mind a bit getting exhaust fumes in my face so il have to look into it a bit more then?
Doesnt sound much like fun :(
How about routing the downpipe as normal and having it exit just behind the real wheel, kind of like the Merc SLR.....
Maybe have a screamer pipe exit down there as well :twisted:
James
'91 325i Sport
'93 318i touring 16v
Colonel Sanders
Post Tue Aug 07, 2007 10:54 pm
well the reason i want to go out the wing really is i want a BIG downpipe an heard its a right bitch to get a 3" past the steering let alone a 3.5 what i want mate! just worried it will be too loud!!!!
jmc330i
Post Tue Aug 07, 2007 11:15 pm
Assuming the turbo will have the exhaust side at the rear of the engine (as normal I think), routing the pipe back round the front to exit in front of the wheel wont be that easy will it???
James
'91 325i Sport
Colonel Sanders
Post Wed Aug 08, 2007 7:44 am
no, it wont! i could go behind the front wheel, but either way im in a bit of a pickle!!!
jmc330i
Post Wed Aug 08, 2007 4:35 pm
Just been thinking about this. How about running the downpipe out through the inner wing near the battery tray.
I dont know what space there is behind the wheel inside the wing, but you could maybe run it across the battery tray (or below it), through the inner wing, have a smaller silencer behind the wing and exit just in front of the door. I dont know what structural stuff there is there, but its maybe an option.
James
'91 325i Sport
Colonel Sanders
Post Wed Aug 08, 2007 5:01 pm
yeah this is the way i was thinking, dont think it would harm it too muchas long as i didnt make the hole through any structual joins.. anyone got any ideas of a small but effective silencer? doesnt need to be too quiet but just to cut some of the noise out????
jaistanley
Post Wed Aug 08, 2007 11:54 pm
Supertrap type silencers are low profile..
Jai
Colonel Sanders
Post Thu Aug 09, 2007 12:26 am
how big are they?
Colonel Sanders
Post Thu Aug 09, 2007 12:27 am
how big are they?
Colonel Sanders
Post Mon Aug 20, 2007 11:43 pm
wohooo, got the head and injectors fitted tonite gonna wire it up tomorrow but unfortunately forgot to take pics of doin this! but il remember to take some tomorrow, still need to put the cam belt on though, although i did remember to set it to tdc...
feeling the boosted m20 is getting soooo close i can smell the burning rubber!!
Colonel Sanders
Post Tue Aug 21, 2007 10:25 pm
been out puttin all the belts back on tonight still got a long way to go, theres a hell of a lot of ms wiring to do but im that bit closer to being boosted!! just waiting on me intercooler, tial 44 wastegate and me big a$$ holset hx35. a few pics for you lot....
jojoejoez
Post Thu Aug 23, 2007 2:08 am
How about your turbo manifold. Do you have any picture ?
Colonel Sanders
Post Thu Aug 23, 2007 5:26 pm
yep il take a couple tonite as im goin down there any way an il post them up. aint put it on yet as im still waitin for my mocal oil filter relocation kit as the manifold fouls it. still gotta take the old exhaust system otta the way too. use a sabre saw to make things quicker......... :twisted:
Colonel Sanders
Post Thu Aug 23, 2007 10:29 pm
pics as requested. the manifold
and a couple of me brand new wilwood 280mm brake kit to stop me with. would have gone bigger but needed something to fit under 16" wheels. aint bought them yet but getting schmit modern line splitrims... winkeye
oldroydsr4
Post Fri Aug 24, 2007 5:46 pm
I belive you can fit 310mm under 16" and on some wheels you can fit 312mm kit from 300mm.de
Colonel Sanders
Post Fri Aug 24, 2007 10:55 pm
aint changin these now as they cos me almost 600 spondoolys!!
oldroydsr4
Post Sat Aug 25, 2007 9:29 pm
Fair enough mate
bigbhpwannabe
Post Thu Aug 30, 2007 7:31 pm
hi rossle nice manifold were did you get her from ? what size flage is it ??
gary]
Colonel Sanders
Post Thu Aug 30, 2007 8:09 pm
bought off a bloke on here for 150 quid, think its one from europe he said? its a t3 flange. nice manifold but had to move the oil filter to get it on!!!
bigbhpwannabe
Post Thu Aug 30, 2007 8:19 pm
oh ok i am haveing a bit of trouble findeing a t4 flange manifold with external gate :o think i may have to have one made keep meaning to mail ant to see if he can get one but this is a very slow moveing project and every time i seem to get some cash up to spend on it me cossie brakes :cry: f-ing ford
Colonel Sanders
Post Thu Aug 30, 2007 8:31 pm
i had a couple of them, and the trouble they bring... maybe my driving!! ants a good bloke, very helpful! john volk told me his 666fabrication manifolds work and they aint too pricey.
hopin to get mine runnin soon, just wired the ms up now still waitin for my turbo and wastegate..
bigbhpwannabe
Post Fri Aug 31, 2007 6:44 am
oh no dont tell me that lol what sort of probs did you have ?? good luck startin her up :cool:
Colonel Sanders
Post Fri Aug 31, 2007 12:37 pm
with the cossies or the e30? only trouble i had with the e30 is, snapped starter moter tryin to get the wires off and snapped a head bolt fittin my mls gasket. with the cossies had all sorts from a crank sh!tting itself to the little boost solinoid not working.
bigbhpwannabe
Post Fri Aug 31, 2007 9:23 pm
oh ok i thought that you ment with external wate gates , :D
Colonel Sanders
Post Fri Aug 31, 2007 9:26 pm
ah no aint got that yet but its gonna be trouble! gotta cut up the manifold to fit the wastegate yet!!
jojoejoez
Post Sun Sep 02, 2007 6:21 pm
With this turbo manifold do you have any problem with downpipe ?
Colonel Sanders
Post Sun Sep 02, 2007 7:54 pm
havent got as far as the downpipe yet but looks like it will be a bugger, but need 3 inch at least!
