Who will fit an e36 m3 engine in an e30?? companies??
bmwonly
Unapproved Trader caution
Post Tue Aug 28, 2007 11:36 pm
With my last idea falling through and completely having the buzz for doing this i need some more info.
Basiclly i dont have the time to the engine work, but i got the time to source the parts and got a bit of spare cash.
The car is going to be a touring, i currently a solid example but i am looking around for 1 with the kit already on with good body work.
I need to speak to some1 about fitting the engine. i'm not bothered if it a tip top bmw company or joe bloggs down the road. As long as they do the job properly.
Can any1 point me in the right direction???
brian325i
Post Tue Aug 28, 2007 11:49 pm
piston heads,zoner is selling a touring with e36 m3 engine,mint car
S50 is alive :-)
bmwonly
Post Tue Aug 28, 2007 11:53 pm
would it be the blue 1 thats sold?? was close to a tear when i missed out on that. if not tell me more
As above, no way you would build one for the price he is selling his for 8)
Kos
Post Tue Aug 28, 2007 11:56 pm
CPC, phil crouch the owner could be tempted to do one for you
01895 252288
bmwonly
Post Wed Aug 29, 2007 12:04 am
l'll bell him tomorrow see if he's interested in doing something
Post Wed Aug 29, 2007 1:11 am
its a 6k conversion to diy.. i'd cry if i heard a quote for someone doing it for me.
bmwonly
Post Wed Aug 29, 2007 9:00 am
I cant see where every1 is getting this 6 grand from??
1500 to 2500 engine loom ecu.
100 squid for 328 gear box
500 exhaust.
1000 for bits and bobs.
wheres the othe 2- 2500 grand gone???
Chris-W
Post Wed Aug 29, 2007 9:39 am
Labour?
Post Wed Aug 29, 2007 11:14 am
diff..?
prop?
sump etc?
manifold work is expensive, 1k in 'our' case, exhaust - no e30 one will fit and work, custom only..
1k for bits and bobs.. well ive spent prob nearly double that
labour its gonna be a week or 2's work @50/hr min
servo/brake solution?
i walked into this thinking 6k was rubbish.. i now know better
jmc330i
Post Wed Aug 29, 2007 12:07 pm
bmwonly wrote: wheres the othe 2- 2500 grand gone???
Labour and all the other bits that need uprating to cope - brakes, suspension etc etc. A conversion like this isnt just a case of slapping an engine in and driving away.
6k is about right for DIY, like Jhonno said, you think it will be less but it soon all adds up :cry:
I seem to remember quotes for 9k-10k when I asked a few places 8O
James
'91 325i Sport
'93 318i touring 16v
ste
Post Wed Aug 29, 2007 12:32 pm
Yep those costs certainly add up... :mad:
snoops
Major Helmet
Post Wed Aug 29, 2007 3:19 pm
8O
Ant
Retired Team Member
Retired Team Member
Post Wed Aug 29, 2007 5:51 pm
Scary innit !
and you still end up with a S/hand engine that may, or may not be up for the job.
Many people on here have been burned by this conversion, I'd not hand over a penny for any engine unless I could hear it running.
Post Wed Aug 29, 2007 5:58 pm
Ant wrote:Scary innit !
*puts hand up*
Never buy an engine you havent heard running at this price..
ste
Post Wed Aug 29, 2007 6:27 pm
also puts hand up... :D
Mine is sorted now and turned out to be something silly but I totally agree Ant.
Post Wed Aug 29, 2007 8:27 pm
What was it Ste?
bmwonly
Post Wed Aug 29, 2007 9:34 pm
Ya cant really cost labour charge in a diy job.
And £50 an hour? Is that a real charge or a guessed 1?? I dont charge that and my unit and running costs are massive. If yes is the case i recon i'll do the converstion myself so i know the in's and out's then charge to do it. could fit in nice when i have quite spots.
Jhonno wrote:diff..?
I thought the diff was E30??
I see what ya all sayin now though. the extra bit n bobs gonna add up.
I take it all back 6g does sound bout right :notworthy:
May be i'll just stick with the good olde 2.5 lump and me touring shitter.
Post Wed Aug 29, 2007 9:39 pm
Yeah £50 an hr is a good indy/garage rate.. That is the costs tho, believe us, there are 5 or 6 people on the forum who have done it now and its always worked out about the same £Â£
Diff is an e30 m3 diff.. Rare and expensive
People have been quoted before and 9/10k is about right for someone to do it for you, its not an easy conversion at all
Cabrio
Post Wed Aug 29, 2007 10:54 pm
You can try the E30 centre in Wolverhampton as they will also have all the parts to do the conversion which will save some £Â£Ã‚£Ã‚£ cheers
bmwonly
Post Wed Aug 29, 2007 11:30 pm
Bit far, but do you have a number??
Kos
Post Wed Aug 29, 2007 11:37 pm
being a project and that its a never simple !"drive in drive" concersion at times , stanadrd labour rates do drop especailly if its a fill in long term job.
also, a competant garage will need the correct diagnostic equipment to see what what on these engines and ecu. doing the wiring can atke up a lot of time, depending how you want it done.
the car phil (CPC ) did was for a bloke on here, called Mfree there is a thred on it some where. his loom was shortened to fit under the normal wiring cover in an e30 to look ar factory as posible :mad:
Post Wed Aug 29, 2007 11:38 pm
bmwonly wrote:Ya cant really cost labour charge in a diy job.
So you have your own business? Then why would you want to pay someone to do the work?
Loving the combination of text talk and old english :)
jmc330i
Post Wed Aug 29, 2007 11:43 pm
bmwonly wrote: I take it all back 6g does sound bout right :notworthy:
M50/M52 conversion maybe???
James
'91 325i Sport
ste
Post Thu Aug 30, 2007 9:09 am
Kos wrote: the car phil (CPC ) did was for a bloke on here, called Mfree there is a thred on it some where. his loom was shortened to fit under the normal wiring cover in an e30 to look ar factory as posible :mad:
Totally unnecessary. My loom wasn't shortened and still went under the standard 4-pot cover and the ECU is in the correct E30 place and looks 100% factory.
DanThe wrote: What was it Ste?
No woodruff key!!!
The crank damper pulley was attached to the dowelled pulley fine, the problem was that was in a random position and it was a complete fluke it ran at all. Key fitted and the pulleys back on it works perfectly. Why the key had been removed I do not know... :mad:
As for £6k to do the conversion, maybe, even more so with an S50. I reckon I've spent nearer to £2k by cunning buying and selling bits along the way. That includes fitting Sport leather, 4 pots, coilovers and the wheels etc.. I'm a tight Northern monkey though. :D
fuzzy
He who sleeps with "Gingers"
Post Thu Aug 30, 2007 1:40 pm
up here its more like £20+ an hour for the sort of little garages that would tackle this sort of work. the guy that does all my work is exactly £20 an hour .
bmwonly
Post Thu Aug 30, 2007 8:43 pm
It's not a garage though. Could prob build one of those MDF land rovers. But my works up n down so get free spaces.
As for the typin thing i'd call it a short hand for computers, quick to type and easy to read. Maybe. or maybe i'm talkin bollox.
ha
bootyman
Post Fri Aug 31, 2007 6:57 am
I think with any mods, there are always hidden cost that you dont account for in the begining. Whatever you think it will cost you, you should always double it and chances are, you will need it all. I cant think of a single thing which has come in on budget on my car apart from the couple of things i've bought in a shop and not had fabricated.
I dont know if he's telling porkies, but a old friend of mine has a E36 cab and he got a 3.2 Evo lump fitted for just over £3k including parts and labour. He said the guy was interested in doing a conversion for me for the same price as my car like his car, was going to be featured and it was free publicity for him. I was really tempted, but opted on the twin turbo in the end because i wasnt keen on giving my car to someone up north i didnt know for weeks. That and the fact that i'm sure the engine would be a lot simpler to fit in a E36 than a E30 and even though they said they had done a couple in a E30 before, i didnt believe them. 8O
Kos
Post Fri Aug 31, 2007 2:42 pm
i know ian332i has the original e36 m3 loom and trunking etc on his car (he did last time i saw it ) ans the owner of this car Mfree wasnt keen on it.
anyway i'm not a wiring or auto electric person, so i stay well out of these things. what i'd like to see is a smoothed engine bay like they do in the VW's 8)
ste
Post Fri Aug 31, 2007 3:43 pm
Kos wrote: anyway i'm not a wiring or auto electric person, so i stay well out of these things. what i'd like to see is a smoothed engine bay like they do in the VW's 8)
I'm crap with wiring too - Ian sorted the loom on my car and I squeezed it under the 4-pot cover.
I'd love a smoothed bay. I've removed a few things but would love the time to do it properly.
Kos
Post Fri Aug 31, 2007 4:49 pm
i did think about it on the m3 i'm building but i can see it cracking and not lasting. seen a few of the westside cars over the years which have had it done, but their cars are near enough show only, where as i plan to use the M3 as much as posible, and drive it hard.
lost a few things from the engine bay, brackets which are nnot needed and studs etc, thats as far as i'll take it.
Colonel Sanders
Le Surrender Monkey.
Location: guernsey.... i mean france munching on garlic and drinking wine with my children.
Post Fri Aug 31, 2007 5:10 pm
fuzzy wrote:up here its more like £20+ an hour for the sort of little garages that would tackle this sort of work. the guy that does all my work is exactly £20 an hour .
thats cheap, my local bmw garage is almost 200 quid an hour!!!!!
ian332isport
Post Sat Sep 01, 2007 8:49 am
bootyman wrote:I dont know if he's telling porkies, but a old friend of mine has a E36 cab and he got a 3.2 Evo lump fitted for just over £3k including parts and labour.
Fitting an S50 M3 lump into another E36 is basically a straight swap, and the wiring is plug 'n' play. Fitting it in an E30, is a whole different prospect. It's easy enough to get the basic lump sitting in the bay on it's mounts, but getting it hooked up and running is a huge amount of extra work.
Ian.
jmc330i
Post Sat Sep 01, 2007 10:28 am
Kos wrote: what i'd like to see is a smoothed engine bay like they do in the VW's 8)
:cool: :cool:
James
'91 325i Sport
Kos
Post Sat Sep 01, 2007 11:50 pm
oooh, i like that
mine will be similar i hope, one thing i didnt do was weld up the holes on the trays behind the headlamps.
