washer jets stopped working..???
aceraf
Tue Aug 21, 2007 11:22 pm
My washer jets have stopped working....
when you pull the lever it doesn't make the normal buzzing sound it should...
checked to see if there were any blown fuses and there weren't!
Checked the wiring plug on the side of the reservoir and it seemed fine...
and yes the reservoir is full of fluid!!!!
any ideas??? :?
Breaking 325i Touring
zimmerbimmer1
BMW Parts Meister
Tue Aug 21, 2007 11:54 pm
Does the motor work when you pull the lever???
If yes then check the T shaped one way valve on the bonnet for blockage
aceraf
Wed Aug 22, 2007 7:09 am
No, it doesn't make any noise now!
Where is the valve? is it hidden under the inside skin of the bonnet?
Rosc0PColtrane
Wed Aug 22, 2007 7:14 am
The valve sits between the two jets under the bonnet. It's a cylinderical white affair with 3 pipes coming off it. When the jets get blocket, it had valves that piss the liquid out all over the place, under the bonnet for you, rather than stress the motor.
I replaced mine with a regular T bar from Halfrauds.
Smell the motor, if it smells like a knackered Scalextric car, then it's burned out.
You have a multimeter?
aceraf
Wed Aug 22, 2007 5:23 pm
I'd say the motor is probably knackered then, as it doesn't make any noise, and it's not losing any fluid either(washer fluid that is)...topped it up a week ago, and it's still the same.
Chris-W
Wed Aug 22, 2007 5:47 pm
Let me know if you need a washer pump.
Cheers,
Chris
jmc330i
Wed Aug 22, 2007 5:48 pm
Forget the multimeter, you need a high-tech tester - 2 bits of wire and a bulb. Connect it up to the plug and see if it lights up when you pull the lever.
My tester is the ultra delux model - two small croc clips, two lengths of wire and an old motorbike indicator screwed to a block of wood 8)
James
'91 325i Sport
'93 318i touring 16v
student
Thu Aug 23, 2007 8:44 pm
mine keep doin this, but occasionally work. ive put a feed to the motors and they work, and i have a feed fron the stalk, but still has a mind of its own?!?
jcjdavis1
Thu Aug 23, 2007 9:12 pm
Hi Try cleaning the contacts with emery paper on the wiper stalk on the steering column.Fixed mine.
josh-hocking
Teenager with Taste !
Thu Aug 23, 2007 9:17 pm
i replaced mine with a regular T bar from Halfrauds.
i bought a proper one from the dealers! only 3quid!!
student
Thu Aug 23, 2007 9:30 pm
jcjdavis1 wrote:Hi Try cleaning the contacts with emery paper on the wiper stalk on the steering column.Fixed mine.
will try that cheers.
