hI DOES ANY NO WEATHER A 325I M50 ENGINE WILL FIT IN MY E30 IF SO WHAT DO I NEED ?
CHEERS WEEDEN[/b]
M50 ENGINE CONVERTION INTO E30 320I WILL IT GO ?
ajm-e30
it certainly will as my mate is halfway through the conversion, you will need e34 g/box, ecu+loom, manifolds, radiator, hoses, the most important thing is the engine obviously, theres probably loads more i havent mentioned.
hth adam
hth adam
Weeden wrote:hI DOES ANY NO WEATHER A 325I M50 ENGINE WILL FIT IN MY E30 IF SO WHAT DO I NEED ?
And an E34 525i/520i M50 sump and oil pick up pipe - the E36 325i M50 sump etc will not work.ajm-e30 wrote:it certainly will as my mate is halfway through the conversion, you will need e34 g/box, ecu+loom, manifolds, radiator, hoses, the most important thing is the engine obviously, theres probably loads more i havent mentioned.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
