Heater Control Question?
Mhiran
Sun Aug 19, 2007 10:03 pm
I am currently in the process of designing a custom dash, and I do not have access to the car as of yet. Does anyone know if the heater controls are controlled by potentiometers and electronic components or if they are controlled by any other mechanical means like wire under tension, similar to cycle brake wire?
Mhiran
smithy318i
Sun Aug 19, 2007 10:31 pm
Hot/cold knob is a rheostat.
airduct adjustments are mechanical wires.
Fan switch is a switch in series with a resistor matrix.
Mhiran
Sun Aug 19, 2007 10:35 pm
Any ideas as to how to extend mechanical wires for the airduct adjustments?
Martinaston
I think the hot/cold has a cable as well :?
There is NO nucleus.
smithy318i
Sun Aug 19, 2007 10:41 pm
Martinaston wrote:I think the hot/cold has a cable as well :?
Your correct. The part i thought was a pot was in fact a switch.
Mhiran
Sun Aug 19, 2007 10:44 pm
Hmmm.. that puts a huge glitch in my plans.. Does anyone know how much play there is in the system. So can the controls be realistically moved to anywhere else on the dash?
Martinaston
Sun Aug 19, 2007 10:49 pm
No reason why not, you just need to use longer cables.
smithy318i
Sun Aug 19, 2007 10:50 pm
Im sure you could move it as long as you extend the cables.
Idol
Tue Aug 21, 2007 12:42 pm
You could exteend the cables using electrical connectors with the screws in. (chocky block) :?: ..... Maybey??
**BANNED**
Tue Aug 21, 2007 1:22 pm
How do the kitcar experts get around this problem?There must be aspecialist who can make bowden cables to order...
