replacing front fogs with driving lamps
trigger
Thu Aug 16, 2007 11:26 pm
im replacing my front fogs with with 55 watt driving lamps, does anyone know if i can just use existing wiring and do a straight swap? cheers
E30Mark
Fri Aug 17, 2007 8:18 am
I'm certain 'driving lamps' have to be a minimum distance up off the floor, but i might be wrong.
The fact that the original fog lamps are 55w means the wiring is OK.
But if you insist on dazzling on coming traffic, then be prepared for the fines from the boys in blue.
PM for details
Andy325i
Fri Aug 17, 2007 4:41 pm
When I bought mine (new) going back some years the boxes actually read "Driving Lamps"
Tried explaining this to a copper once. He was having none of it lol
Andy
Gortour
Fri Aug 17, 2007 5:27 pm
As far as I'm aware, driving lamps go above the bumper, fog lights go below.
I think also, that driving lamps must be wired into the high beam circuit.
oze30
Fri Aug 17, 2007 6:52 pm
In oz, They cant be higher than 1 metre off the ground, nad must be wired into the High beam with a seperate switch.
