DAMPNESS IN DOOR CAVITIES?
Martinaston
Hoover it out and make sure the drain holes are open, and check the seal at the bottom of the window has not gone stiff.
There is NO nucleus.
Martinaston
Should be
- murran
some water is bound to get past the weather sprips, should go out the bottom drain holes tho. make sure the plastic membraine thing in the door is in good nick and well stuck on (areosol spray glues best) or that water will come in the car.
e21 killing tyres with e30 325 powerzzz
drifting on the cheap......... www.trampdrift.com
e21zone........ www.bmwe21.net
