I spent a fair of yesterday working on the beemer again.
The heated front windscreen has arrived. When the time is right we will have this professionally fitted. No point breaking it for a few quid.
My brake bias valve and bonnet pins have also arrived.
The car was moved into a bay ready to start work
My friend Jimmy arrived and set to work cheese wiring the window aerial off. This took a little elbow greese.
Next up he removed the tool box foam surrounding, that was a hell of a job too.
With the plastic windows in place and the retainers removed there is nothing to stop them falling down. brackets were made and fitted to stop this happening.
With that done we carried on with the ally door panels and nibbled the first door out. A little more came out after this picture was taken and the edges cleaned up. It is amazing just how light the door now is.
After that Gareth took to rationalising the wiring. If it had no business being there it was removed. Again the weight which came out was suprising.
I continued with scraping the tar out of the inside of the car. Something I started about 8 months ago
When the doors have been finished all that remains is for the inside to be completley cleaned and any remaining trim removed. Then it's off to the spray shop for 4 weeks. That should be happening in 2 weeks time.
While I was there I had the chance to drive another friends golf. With a circa 200-210bhp engine and properly sorted suspension and brakes this was a very nice experience. Even on Shrick (spelling) cams the car would pull cleanly from 1500rpm and I really had no need to go above about 5500rpm. I look forward to having a passneger lap in this at the ring shortly.
Next update to follow.
