Rust on your E30?
323i_rare
Sat Dec 09, 2006 4:58 pm
Makes me want to cry :cry:
thebigone
Sat Dec 09, 2006 5:37 pm
may be I'am lucky, but my cab is "R" free :D :D :D :D
Simon
Sat Dec 09, 2006 5:59 pm
My touring is mostly rust free, tiny scab on the sunroof, and that's it, tourings are normally very good.
M3 did have quite a few rust problems, all the major areas have been sorted, the usual problem where the exhaust manifold comes close to the chassis leg still exsists though, and that will be an engine out job.
Cotty
Hartge Crew
Sat Dec 09, 2006 8:14 pm
Simon wrote:My touring is mostly rust free, tiny scab on the sunroof, and that's it, tourings are normally very good.
Touch wood mine only has a tiny spot of rust under the tailgate (not visible when shut)
Oh and the many stone chips that are starting to turn orange :(
Jesus325iTouring
Frog freak !
Frog freak !
Sat Dec 09, 2006 11:42 pm
I've a tiny bit on the tailgate,only minor surface and barely noticable,the bottom of the drivers door needs a bit of attention,again,not really noticable and finally that tiny hole recently discovered on the front suspension turret.
Overall my Tourers pretty remarkable for the miles it's travelled.
Underside is absolutly mint,I scraped and re-undersealed it about 2 years ago,and also it's had a fine layer of oil spread over the chassis's entirety which has kept any rust away,one advantage of having an engine which p1ssed oil out!
When my insurance job goes through all the niggly bits will be done,be back to totally rust free again :D :D :D :D
stuartgallafant
Sat Dec 09, 2006 11:46 pm
i have 1 SMALL bubble on my sunroof panel, and another SMALL bubble on my NSR arch :(
Jesus325iTouring
Frog freak !
Frog freak !
Sat Dec 09, 2006 11:51 pm
Was this the M3 you looked at before you bought it that had the scary looking rust under the front wind screen Si?
How did you deal with it?
Confusing question now I've read it back,but i'm sure you'll know what I mean! 8O 8O
KDS
Sun Dec 10, 2006 6:17 am
My Touring did me the favour of only rusting in panels that could easily be replaced and where spreading wouldn't occur. The tailgate looked rust-free, but had bad rot hiding behind the license plate trim, and the sunroof panel was toast. Nothing else. I've had all the door and boot trim off and there's not even any surface rust where metal meets metal. By the time BMW built the E30, they'd come a LONG way from their rust-prone 2002s. I fought rust on a '72 for 13 long years!
-KDS in Vancouver ('88 325i Touring)
Simon
Sun Dec 10, 2006 1:28 pm
Not confusing at all!
Yes, same car, bodyshop cut out the end sections of the scuttle panel, from about where the scuttle grills are either end, and replaced with the parts from a new scuttle I bought from BMW, luckily for me the rust was located down low on the scuttle, not under the windscreen seal.
bmwsport
Thu Aug 09, 2007 7:50 pm
WillG wrote:front jackin points have all started to go by now from what ive seen, ive repaired 3, thats where they start and then they go along where the seam where the floor pan joins bulkhead, mnst have gone above the fuel vapour bottle thing in drivers side rear inner arch aswell i expect
Is the fuel tank vapour bottle really neccessary or can it get binned?
munky30
100% Pure Council
Thu Aug 09, 2007 7:54 pm
Inner arches? - Clear
Outer arches?! - Clear
Sunroof panel? - Clear
Inside sunroof? - Haven't dared to look
Doors? - Front two at the bottom corner
Inside boot? - Clear
Under carpet? - Clear
Scuttle? - big hole
None anywhere else.
touringandy
Thu Aug 09, 2007 9:24 pm
rust two places tailgate and just under the windscreen by the plastic vent
"great" failing that dont really want to start searching for any appears free any were else :mad:
Frenchy
Thu Aug 09, 2007 9:52 pm
Tiny blister about the size of a 5p piece on the NS arch lip..thats it!
Getting sorted in winter.
Alpina B3 3.3 Santorini Blue,White Buffalo hide with Blue Piping,Black Shadowline. No 242.
318 iS Diamond Schwarz.
Porsche 944 Turbo S,Special Order Black,Very Limited Numbers and Very Quick......;-)
georgen
Thu Aug 09, 2007 10:02 pm
My tailgate is absoloutly hanging, along with the sunroof inside. New tailgate getting fitted after my hols though. God knows what multitude of sins the tech II kit is hiding, but the rest of the car is rot free !!
01' 330ci Sport
02' 530i Sport Saloon
52' 330i Individual Touring
Danhbmw
Thu Aug 09, 2007 10:19 pm
I've got a little bit on the bonnet that just needs touching in!!
HairyScreech
Thu Aug 09, 2007 11:18 pm
how in the name of jesus did you get it rusting like that!?
mines fairly clear, been under everything and all i can find is a little in the front left wheel arch where the turret meets the chassis rail, shouldnt be to bad to sort that either. (well not for me, i have a mig and im not afraid to use it)
Greeny
Fri Aug 10, 2007 12:45 am
My rear arches are just starting to look a little scabby.
Gone but not forgotten.
('92 325i Cabriolet)
Kos
Fri Aug 10, 2007 1:06 am
there is always more than what you think there is, when you take the car apart you find it, often its hidden.
i know for a fact that my M3 is rust free
jaimie, your dad should have put in a new scuttle 8O
www.pukardesigns.com
IG Pukar.Designs
snoops
Major Helmet
Fri Aug 10, 2007 1:45 am
on the car I just broke a facelift 325i there was only rust on the front jacking points and rear of both sills, everything else was clear and much to my surprise the sunroof panel looked like new! was expecting to find holes and lots of rust under the carpet but only slight by the jacking points, rear arch had bubbles but that was it
fozzymandeus
Fri Aug 10, 2007 8:12 am
Mine has very little rust on it, but unfortunately somebody fitted front mudflaps in the past :(
Removing those revealed corroded front wings, which I'm repairing myself... so it'll probably come back straight away!
StriderDriver
Fri Aug 10, 2007 8:30 am
'88 325i Touring
Inner arches? tiny bit of bubbling on the inner lip
Outer arches? none
Sunroof panel? none
Inside sunroof? none
Doors? none
Inside boot? none
Under carpet? none
Scuttle? none
Tail gate? tiny bit of bubbling above the badge
stranter
Fri Aug 10, 2007 9:55 am
My chrome 2dr E plate 318i is rust free bar a 10p size scab on a rear arch. And I mean no rust anywhere else, not in the sunroof, under the carpets, jacking points, scuttle panel and it has never been welded.
Rust free examples do exist!
Stewart
pictonroad
Fri Aug 10, 2007 1:09 pm
Nowt.
Not anywhere, I've had all the trim off, bulkhead revealed, carpets up etc......
Non, nada, nothing, zero and none.
Fri Aug 10, 2007 10:21 pm
Danhbmw wrote:I've got a little bit on the bonnet that just needs touching in!!
Even the plastic bumper looks likes it has rust bubbles on it! Or resprayed in the middle of a dust storm.
oguz327
Captain Armco
Captain Armco
Fri Aug 10, 2007 11:54 pm
Mines never been welded as yet, rear valence has a bit of crust and theres a bit of surface rust on one of the jacking points and sun roof but otherwise clear.
My old tech 1 ODE, was a different story :D
JMRe30
Sat Aug 11, 2007 11:49 am
my rear arches show some bubbles. there were two buckets of dirt trapped behind them. cleaned and painted with hammerite. 2 spots in the doorsills with some slight bubbling around them, which i have yet to take care of. otherwise it's pretty much rust-free
