What rad is this.
gooner1
Out humping Reindeer
Post Sun Aug 05, 2007 5:18 pm
Longshot i know just from this pic but anyone know what model this rad is from. An easier question also what is this plastic item?
Post Sun Aug 05, 2007 8:32 pm
Looks to me like an E34 M30 engines rad, if its 550mm wide.
Have you got any dimensions?
Ideal for M50/M52 engine transplant winkeye
Strange temp sender though :?
gooner1
Post Sun Aug 05, 2007 8:52 pm
Dan The.its 4550 or 18inches high, 6250 or 24 3quarter inches wide(from core to core) and 450 or 2 inches across.
Does that help?
Post Sun Aug 05, 2007 9:07 pm
6250 wide? Thats very wide!! I think you mean 625. The core is the alloy bit in the middle from which the measurement should be taken, I think you are measuring from the outside edges of the side tanks?
gooner1
Post Sun Aug 05, 2007 9:13 pm
Yes Dan thats the part i measured from , 24 and three quarter inches from the alloy edge to edge.
Will take a pic tomorrow with it against a E28 rad.
Post Sun Aug 05, 2007 9:21 pm
Could be from an E32 or an air-con model E34 then. Wont fit an E30 in that case.
gareth
Post Sun Aug 05, 2007 10:04 pm
looks like an E32 one to me.
it'll go halfway in a E30 before the end tank stops it. very similar to the E28 one apart from the end tank shape.
