does anyone know the owner of this site: http://e30m3performance.com/index.html
according to the blurb, it's owned by a Dr Gustave Stroes.
i want to let him know of the error but can't find his contact details...
Picture, details of toe/camber correction subframes
gareth
ian332isport
You should be able to contact Gustave here:gareth wrote:does anyone know the owner of this site: http://e30m3performance.com/index.html
gustave@gsperformance.com
Cheers,
Ian.
gareth
ta again mate!
Dan318-is
Just been reading through this and trying to get my head around it...
I have one question about rear toe...
why would it ever need to be anything other than 0 (e.g. parallel)? surely if they are toeing out slightly then it will just wear the tyres excessively? I understand that a slight amount of toe out on the front improves turn in on corners, but obviously the rear wheels are not steering so what are the benefits?
buster
3Thats why i only fitted camber adjustment dan.
Dan318-is
Hmm interesting. Il see how i feel on the day. What would cause the toe to be out on the rear anyway; worn bushes?
buster
yeah and accident damage possibly to the rear end.
Dan318-is
Hmm hopefully none of that then. Think i may just do the camber adjustment plates then; the ones that go on the inside of the subframe yes?
buster
well i fitted mine to the inside ones but it doesnt matter which you fit them to i believe.
Dan318-is
Sweet! Will keep you updated, think alex is going to be doing the welding for me
