750i brakes
Toby_Unna
Boost Junkie
Wed Aug 01, 2007 6:33 pm
Having trawled through various threads about this brake conversion I thought I'd put one up with my experience. :D
I used standard 750i calipers (£30) and Audi TT 225bhp 312mm discs (£109 pair all in from GSF, for cross-drilled Zimmerman ones). I then paid £20 to have the necessary 1mm taken from the centre bore of the discs along with two extra holes drilled; very straightforward and 1 hour's work max. Mount brackets are currently fabbed from MDF to get the dimensions right (I haven't been able to get a template for the 300mm.de adapters and only started work on this today!); probably get these cut from 20mm steel as the 20mm ish MDF fits with plenty of clearance, and i'm not expecting them to be particularly expensive to make.
Clearance to my 17 inch wheels is plentiful, and I know some 16inch wheels will fit too. The most important thing is that the ofset of the discs is very close to the E30 ones, so no spacers etc required. Obviously no driving impressions yet (!) but I know Ant's tried a similar set up and got on well with it.
Overall seems to be very good value for 312mm brakes, especially as the price of consumables when they wear out will be much more reasonable than say for a Willwood kit.
I understand I'll be ok with the stock e30 M/C, but have the 750i one available if needed - will I need it? bearing in mind that I already have a fairly small brake servo?
Also will the car now be hoplessly underbraked at the rear?
new and old discs before machining
TT discs machined and fitted
caliper fitted on mock-up mount bracket
wheel rim clearance
8)
EDIT: quick plug for Bilt Hamber de-rusting products. they're f**king brilliant!
nickso
Wed Aug 01, 2007 6:39 pm
nice. 8)
i was thinking about going ahead and sorting this out myself after the group buy failed. the only thing that piut me off was i wasnt sure what material to make the adaptor out of. someone mentioned on the group thread that standard steel wasnt a good idea :? dont know why though.
'88 e30 328i M52 track bint.
ed325i
Wed Aug 01, 2007 7:24 pm
They use the e28 535 m/c on 300mm.de
I drilled 3 holes in mine the same as the 300mm.de ones.
You have to use the correct grade of steel what ever that is.
nice work toby 8)
Ant
Retired Team Member
Retired Team Member
Wed Aug 01, 2007 7:29 pm
I used the stock e30 M/cylinder, great feel, not long travel and zero issue to date.
On Dimmys car the brakes were massivily OTT and locked up with slight provocation, once the ABS was sorted out( FUBBARRED) all works as well as could be
Nice Work Toby :thumb:
Turbo-Brown
Boost Junkie
Wed Aug 01, 2007 8:00 pm
When you say the correct grade of steel?
The brackets holding my calipers are made of aluminium to around 8mm thick and haven't snapped off :D
ed325i
Wed Aug 01, 2007 9:06 pm
Its just when I ordered mine tino had to wait for the correct grade of steel to turn up as they sent him the wrong grade.
funky-monkey
Wed Aug 01, 2007 9:23 pm
I guess there's no chance of these fitting under 15"s?
ed325i
Wed Aug 01, 2007 9:30 pm
funky-monkey wrote:I guess there's no chance of these fitting under 15"s?
No.
Andy335Touring
Nice work Toby, now find me some thing similar for my 15's ! :D
no chance :(
Wed Aug 01, 2007 9:53 pm
nice on.. yet again Toby!!
Turbo-Brown
Boost Junkie
Wed Aug 01, 2007 10:03 pm
Fair enough.
Think I'll be making mine out of good ol' mild (subject to calcs of course!) when I get around to it.
EDIT> Ooh! Toby, you couldn't tell me what the dim from the face of the disc that sits against the hub to the inner most face of the disc is could you? And (moon on a stick time) how much clearance there is to the steering knuckle?
Only ask as I got a set of 330Ci discs and have found that they'll fit in my Comp 42 wheels whilst retaining the Wilwood calipers but I've not been able to check that the discs will fit on the legs yet.
Sorry to go off topic dude!
fuzzy
He who sleeps with "Gingers"
Wed Aug 01, 2007 10:19 pm
will you be making up extra caliper mounting brackets to perhaps sell on to fellow zoners attempting this conversion? winkeye
Toby_Unna
Boost Junkie
Wed Aug 01, 2007 10:55 pm
Turbo-Brown wrote: Think I'll be making mine out of good ol' mild when I get around to it.
I was going to add that aluminium is commonly used to mount calipers. I'm going to use mild steel too, and i'm not expecting anything to snap off. as long as it's sensibly spec'd (i.e. nicely overspec) there isn't going to be a problem. the rest of the parts holding the caliper (carrier, strut base) aren't made out of fancy weird grade material, they're made to be cheap :mad:
I'll get some measuring sorted for you tomorrow Alex, no verniers though so it'll be basic ruler and eye stuff :D
Fuzzy, once I have my mounts made I'll know a price. At the very least I'll be able to supply dims/templates (as no-one has yet measured a 300mm.de bracket); they're a nice straightforward design and won't be hard to make/get made 8)
Ed, I thought it looked like 300mm.de only added two holes? I tried to copy what they did anyway.
d1mmy
Boost Junkie
Wed Aug 01, 2007 11:45 pm
Excellent work Toby. My set up is very good. Highly recommend it (with ABS :twisted: )
For sale 325i Sport Turbo & 318i (Sport) M50B25
Greeny
Thu Aug 02, 2007 1:01 am
I might have a go at this conversion myself, I have a lathe and milling machine in the garage so I could modify the disks and make the caliper mount spacer myself.
A cheap big brake conversion :D
Anybody know how easy the 750i calipers are to get hold of?
Gone but not forgotten.
('92 325i Cabriolet)
Martinaston
Thu Aug 02, 2007 1:16 am
The audi A4 1.8 turbo (not quatro) 285mm discs fit under 15 inch wheels.
There is NO nucleus.
lenny-d
Thu Aug 02, 2007 10:41 am
why is everyone using the 750i calipers, wots so special about them as 300mm.de use the calipers of an e36 328i and they're bound to be easier to get the hold of
bigun wrote:sell my sport i'd rather f**k the dog :)
for sale one left kidney, high mileage, need slight bit of work, will p/x for front wings and rear qtr panels
Turbo-Brown
Boost Junkie
Thu Aug 02, 2007 1:54 pm
Ruler and eyecrometer's great dude :thumb:
What I'm hoping for is "there's miles of clearance from the back of the disc to the knuckle" :D
ed325i
Thu Aug 02, 2007 2:06 pm
They drill out that little screw hole. but yours look ok.
You can get hold of blank discs which have no holes in so you can just drill the 4 needed, which is now what Tino is doing.
Toby_Unna
Boost Junkie
Tue Aug 21, 2007 9:51 pm
Finally got the caliper brackets back for these this morning, the bloke making them decided to go on holiday! :x
anyway brackets cost £40 and should do fine. got them on this afternoon and went for a play, and they are very good indeed! no fade, loads of braking power, generally brilliant! being a bit careful while everything beds in and with the discs being new etc, but overall i'm very impressed, well under £200 total spend.
if anyone wants templates of the mount brackets, just ask :cool:
ed325i
Tue Aug 21, 2007 10:11 pm
Nice one :cool: just need to get some m3 calipers for the rear now.
Demlotcrew
Tue Aug 21, 2007 10:34 pm
I felt the pedal to be too soft/long travel with the stock E30 MC so fitted the 25mm one from the 750i.
Good work!
HTH
Theo
Tue Aug 21, 2007 10:43 pm
The bigger master cylinder is a good mod, greatly reduces the stroke of the pedal - well worth doing IMO.
Toby_Unna
Boost Junkie
Tue Aug 21, 2007 10:52 pm
cool thanks for that you two. it's available for nowt from the same place as the calipers, might have to stick it on i guess :cool:
Turbo-Brown
Boost Junkie
Wed Aug 22, 2007 1:44 am
How much clearnace to the knuckle did you have in the end Toby?
Only ask as the 330Ci discs have about 1.5mm when mounted on the 4 stud hubs (just as a trial and they'd need moving out a tiny bit to get the track rod end in) They do give a lot of clearance for pistons on the outside of the disc though :D
Toby_Unna
Boost Junkie
Wed Aug 22, 2007 7:45 am
never measured those dims for you did i Alex :o:
knuckle clearance with these is similar to 325i discs, the offset is very similar.
i'll get the ruler out next time i have a front wheel off mate, sorry about that
Templ8e30
Thu Aug 23, 2007 1:20 am
Any chance you could mail me the templates please Toby ?
Templ8 at hotmail.com
Cheers buddy,
Iain T
2007 Mazda 6 2.0 estate
Quaser
Thu Aug 23, 2007 12:19 pm
What options do 15" BBS wheels have? 285mm discs with which calipers?
toby
Fri Aug 24, 2007 11:09 pm
^ good question!
Martinaston
Sat Aug 25, 2007 12:13 am
E46 with brakets or possibly the E46 M3 set.
toby
Sun Aug 26, 2007 2:04 pm
Martinaston wrote:E46 with brakets or possibly the E46 M3 set.
Thanks, have you done this or are you estimating?
Martinaston
Mon Aug 27, 2007 1:43 am
I bought the bits and had the discs machined and just needed to get the brackets made, but then bought another car so its still sat on the back burner.
The 750 calipers don't fit under the 15' BBS wheels with the 285mm discs though, so i went for the E46 calipers but they don't cover the full face of the disc because they have the smaller pad.
I was hoping that Stuart could get hold of some E46 M3 calipers to have a measure up because they have the same size pads (60mm i think) as the 750i calipers but the body is slimmer, so they would cover the whole face of the disc and i hope fit under the wheels.
Have a search for a thread called "massive brakes" most of it is in there.
Demlotcrew
Mon Aug 27, 2007 9:13 am
The E46 M3 calliper is not slimmer, its a bit bigger than the 750i/540i/M5 callipers.
I was going to use E46 M3 callipers also but found that they were too big to fit inside the 16" hartge wheels and used 540i calliper instead.
HTH
Martinaston
Mon Aug 27, 2007 11:58 am
Is that with the 300mm discs ?
Toby_Unna
Boost Junkie
Mon Aug 27, 2007 12:50 pm
To all that have pm'd about brackets, and everyone else interested, I'll get a proper template drawn up (instead of the grubby drawing I gave the bloke in the machine shop!) as soon as I can and distribute it :cool:
these brakes are brilliant! and for the first time ever my car went though its mot without the tester moaning about the brakes being out of balance/sticking calipers/etc which has to be a good thing!
