what setupn 4 2.7 turbo m20?
hijak001
hey plp me again
i hav a question...would a 2.5 m20 head
on a 2.7 short block giv a low comp..
low enough 4 a turbo..
ur help wid dis is greatly appreciated
k catch ya's
k catch ya's
1an
maxfield
blingsta had a 2.7 turbo but had problems because he was running pretty hih compression.
With a low compression engine then 2.7 would be a sweet thing to turbo.
Ant
- Retired Team Member
I have 3 2.7 turbo projects in the workshop, the CR is the key to this conversion.
only ill advised on ETA cranks due to the weak cast iron nature and long stroke, TD or M52 cranks are stronger than the B25 unit so not an issue, all the converted engines I have built are riunning the TD crank
happy to field a few phone calls on this if you want BTW.
Blingsta was 10.4:1 CR + turbo , hance the Headgasket going into orbit once the boost climed above 8 psi.
Email FTW
turbotel
or a decompression plate /copper gasket a safety valve in other words. this willbe the first item to go should something go wrong depending on what goes wrong. can get you number.
blingsta
- Boost Junkie
Ferriday engineering can provide a decomp plate for £300.. 3mm is what i had but bought it too late...
hijak001
ic so the td crank ...
no da only prob i got is gettin 1 into australia..
oh well will a find way..
fanx 4 da help
fanx 4 da help
cplagz
eta block, rods, crank + 325i pistons, head = low comp IIRC ? ~8-8.5 or something
- **BANNED**
Is a 2.8 crank available in upsidedown land?Be stronger than the eta item,would eta pistons/2.8 crank give a useful starting point?
fuzzy
how come the text talk filter didnt sort this out?hijak001 wrote:hey plp me again
k catch ya's
Colonel Sanders
- Le Surrender Monkey.
- Location: guernsey.... i mean france munching on garlic and drinking wine with my children.
maybe hes "special"
hijak001
hurray i'm special...
lmao..
nah i got no idea y it hasn't
lmao..
