does any1 know if a 320i prop will fit, or if not how much it needs to be shortened by?
i'll keep u all updated, hopefully will go in over the august bank holiday!!!!!!!!
fingers crossed!
Well my engine is as far back as it would go without modding the fire wall, so it could be around P2.5/P3 and there is about 5mm lelft on the sliding joint on the m3 prop.nate335i wrote:ok, can i use the m3 prop even in p3?
Mines was free, came attached to the gearbox!stevetigger wrote:Mine was £90
Damn those feebies!Demlotcrew wrote:Mines was free, came attached to the gearbox!stevetigger wrote:Mine was £90![]()
Andrew
a suitable time to drag this pic out i thinkric325i wrote:
crazy time of year for it!!!!!!!! lets put a huge engine in a rear drive carat the start of winter
Pin 15; black/green wire.charlE30 wrote:Cany anyone just confirm that it is pin 15 on the body side of the E30 loom that need to be connected to the smallest nut on the starter motor to enable the windows and blowers to work correctly??
Cheers BrianBrianmoooore wrote:Pin 15; black/green wire.
I'm going to be using my 325 rad for now as it's 6 months old and fits really well, I'll just keep an eye on the temperature for the time being. I've heard there are two types of E34 535 rad, one fits the other dosen't. I'm going to try and shift some of my spare parts and get a nice new shiny E28 radric325i wrote:dude you say you need a e28 rad im using a e34 rad.
just enough space to squash it in![]()
i think its time to start my m30 thread? the engine got dropped in last night
charlE30 wrote:Cheers BrianBrianmoooore wrote:Pin 15; black/green wire.
Ric what are you using for your screen wash tank??
Cheers mateDRIFTBOY wrote:Nice one Charlie,
Car looks stunning!
