Some good points
3.64 LSD
Inverted Bilstein shocks
-35 or 40mm (can't remember) H&R springs
H&R ARB's
Sparco Strutbrace
6 point SD roll cage
Toyo r888 tyres on 15" BBS (215/50/15)
WMS 280mm front brakes
E30 M3 rear calipers with 280mm Z1 discs
E32 750i 25mm brake master cylinder
Cobra Monaco seat and subframe with sabelt 6 point harness
Superchipped ECU
Some bad points...
I built it!!
Crappy exhaust including some flexi pipe
Every panel has a dent or scrape
PAS refuses to work
Cold air feed which incorporates a couple of joining pieces of drain pipe (sort of ties in with the first bad point!)
Theres a sticker of a dog on the window which I can't get off!
Thanks to all those who have assisted along the way, I wont name you as I'm sure you don't want to be associated with this LOL
