Jhonno wrote:what a spectacular turd! Pacerpete will be creaming himself
So was I!
Then I woke up on sunday with a big hangover and an unimpressed looking girlfriend!
http://cgi.ebay.co.uk/Maserati-Biturbo- ... dZViewItemmattG wrote:Think the handerling may not be much better than a yank,
going to be fun but parts hard to get, pete was looking for a head light silly money iirc.
could sell him yours and stick some e30 one in their.
Good plan!Jhonno wrote:the car has been about 5 different colours
Pleeeease make sure it goes pop big styleee and video it
I know of those but I've never (that I know of) actually seen one. Would love to try one out though, proper wagon!Karan wrote:745i?
[/img]
and if it was there, it would probably not work anyway!DRIFTBOY wrote:No lighter sockets to be found!
oil starvation only happens when the Mi16 is tilted back to get it in (extended bottom mounting fork). ideally you want to cut the exhaust manifold off at the head flange, grind and reweld at a tighter angle so it clears the bulkhead. the standard full length inlet will also fit if the rad is tilted forward. the shortened inlet manifolds tend to cause a flatspot at about 4.5k. tilt the engine right and it'll be fine. if you've not yet found it, check out the 205gtidrivers forumJon_Bmw wrote:Should be a fun little thing. Few mi16 issues that could do with being addressed before its tracked such as the potential oil starvation issue. The thing is they are a relatively cheap engine its almost worth not bothering and then replace them when they break![]()
This one is at least running on the proper management and not an aborted 8v to 16v dizzy convertorAlso has a reangled inlet manifold. It's sad that i'm getting mildy excited about it.
