Has anyone
Sideways-Smiffy
Post Thu Jul 26, 2007 2:13 pm
Put a larger engine than the one that the car is designed for in a (E46)?
Just I have just got a E46 with the engine that is knackerd its a 325ise saloon, I was wondering if it would be possible to put in a 330i or 328 engine in and if so whether its worth the hassle if its hard to do
Cheers in advance
Dan
m-dtech
Unapproved Trader caution
Post Thu Jul 26, 2007 9:39 pm
wrong forum to ask on, most people on here are fanatical geeks of the e30 and get confused when e numbers get big !
ric325i
Post Thu Jul 26, 2007 10:06 pm
m-dtech wrote: get confused when e numbers get big !
cruzin for a bruizin :crutch:
only joking but what you said is funny
Sideways-Smiffy
Post Fri Jul 27, 2007 9:56 am
Ok cheers mate,
I was pointed in this direction, I though it a bit odd that you are E30 guys... I used to have one does that help hee hee
Smiffy
fozzymandeus
Post Fri Jul 27, 2007 10:44 am
I'd just find another 2.5 engine of the same type to put in. Engine swaps in modern cars are a big headache unless you're a wiring genius... all the engines that are more interesting than the one you're replacing have complex immobiliser electronics.
Gunni
Post Fri Jul 27, 2007 10:56 am
There is no different wiring to a E46 2.5 and 3.0
but you do need another ecu, possibly ews and all that stuff and have it adjusted to the car it self,
The conversion it self is just like replacing the engine,
*One quick note, you might be able to have the 2.5 ecu flashed with a 3.0 program.
That should sort things out pretty easily.
With great challenges comes great engineering.
Gunni
@ 2012 VEMS group buy !!
Ant
Retired Team Member
Retired Team Member
Post Fri Jul 27, 2007 4:34 pm
^ Agreed
M54 will interchange quite ahhpily like for like, or indeed 2.5 for 3.0
reflash the ECU as per Gunni's post and jobs jobbed.
turbotel
Post Thu Aug 02, 2007 11:57 pm
hi i am new to the zone but you will be hearing some strange things coming from this man.my belief is strong on individuality. if you want a bigger engine think what you need go and get and fit it. if everyone said no to all the mods we have seen where would we be today, probably behind a poxy reno or ford. i say go for it
