hardtop
dips346
- London Meets Main Man
lot work needs doing as the prep work you cant use fuilds or rub with a machine for too long as the base of the top is fibraglass and you will see plenty of hardtops after a while with the paint bubbling or sinking ,its a lot of labour to do it right as i have done about 4 now
SilverShadow
- Hartge Crew
evil bemer, if yours is the original bmw hardtop with the vynl do you fancy doing a swap with mine??? mine is absolutly mint apart from the vynl starting to bubble on the sides? if you r going to strip yours it wont make a difference, as you will be taking the vynl off?
let me know what you think!
o yeah and dips is your man for doing this job!
I dont pick up the hardtop untill the 4 august from a guy in surrey.i bought off ebay last week i have no probs in swapping but untill i see it im not 100% sure what sort of condition its in,but your welcome to meet me there? pm me and i can give you the details!!!!!!!!!!!!!!!
SilverShadow
- Hartge Crew
you have pm mate!
motorsport
Lot of hard work, well worth it though.
I peeled off the vinyl to reveal the green vinyl adhesive which is a pain to clean off. Took me an absolute age using a water steamer (safest and easiest option, avoid chemical strippers) to loosen it and a plastic spatula type tool to scrape it away once softened. Once you have removed the adhesive be careful as you flatten the fibreglass, as the hardtop is built around a metal honeycombed frame. You don't want to expose the metal frame as it will require a lot more filler primer to build up the surface ready for painting. Take off the rubbers first, including the rear screen seal, as they are really expensive to replace (main seal is Ԛ£200). Basically the process isn't that difficult just a lot of labour.
I would prepare it yourself as the bodyshop will then only have to build up the primer to a flat surface and paint it. If the honeycombed area is exposed too much then it may show through the paint when the hardtop gets a lot of heat/sun.
Get it done, well worth it.
Andy
Andy
- mineralblue
- Rocking Horse Poo
That looks soooooo nice, is that an original roof stripped back I take it?
