tech 1 on a facelift ????
- KINGOFSNAKE
can i fit a tech 1 kit on a facelift model ???? at the moment its only the bumper fixings i think i need to address that is the face lift bolts from beneath and the tech 1 bolts through the front
Basically you can but then you need all the stuff from pre-facelift. Rear bumper is different (rear arches are different in pre-facelift) but front end is easy if you have all the parts.
Can't see any sense in doing that, though.
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
Nelly's thread should help you out a bit mate,lots of work involved tho-
Good luck
Good luck
