in the process of trying to sort a diff out. im looking for some information, what sort of power are the e30 diffs good for? is there a different between small and large case?
i need something that will not break with lots of power, but dont want to use a m5 as there very heavy.
and can the diffs be rebuilt to a 2way drift style diff, what types do the drifters on here use. thanks.
LSD mods
DRIFTBOY
I can't specifically answer those questions but you might find this thread interesting / useful.
http://www.e30zone.net/modules.php?name ... hlight=cwp
kevo
Hiya, i've machined several sets of ramp angles in lsd out of 325's i used a ford clutch pack in mine the ramp angles made it lock up superbly well too. if you're interested i could be tempted to machine yours.
Kev
Kev
nigel79
thanks kevo may def be interested in that. does it make it better for drifting or circuit driving. anyone still know what max power the diffs can normally handle.
GermanGorilla
Hi,
Kevo- Can you please PM me a price for the following if your
interested -
E30 Med / Large Case Diff 3.73 LSD.
Remove CW/P, and standard dual BMW Clutch Plates.
Alter and re- harden the Ramp Angles to 70-30.
Fit the Ford Atlas 4 clutch pack/ set to 40% lock up
Remove the timing Triggers.
Reset, and then re-assemble Diff.
Wait to hear from you, hopefully.
Regards,
The Gorilla.
interested -
Regards,
The Gorilla.
Nelly
- Gumbo
CraigG
if your wanting a decent LSD, ditch the shitty OEM style and get a plate style locker. TranX or Gripper. i suppose an quaife ATB would also be mucho better than standard, albeit not as good as a plate type.
nigel79
what about those obx ones that are or flee bay from the states, are they any good or are they just cheap chinese rubbish.
kevo could i also have a price on that diff rebiuld as well, as now very interested. sounds like a good set up.
