Project "Kiev Express" Updated 8/03/09
320Touring
Post Sat Jul 21, 2007 12:27 am
Finally got the chance to get torn into the touring today...
Painted for 10 straight hrs, all I can smell is hammerite
First off- Cleaned and painted the struts zedone (bruce) sent me. Look to be in good order- fairly new springs and have decent callipers with the all important working bleed nipples!
You can see the matching -40mm rear springs too, although I think they're for a saloon....
Next up, the sills got a thorough sanding and a coat or two of Hammerite. They were remarkably solid, and should survive well once I spray waxoyl through the SE sideskirt holes.
Next up, I tackled the fun stuff... Painting the underside of the car...
It was a PITA, but I'm sure you'll agree it makes her look much better!
Then it was time to wield the grinder on the Jacking Points....
To my surprise, the drivers one was solid, so I just chopped off part of the JP and cleaned, rust proofed and painted it.
The passengers side had taken up religion, or at least it was holey...
So further tomfoolery awaits it!
Jesus325iTouring
Frog freak !
Frog freak !
Post Sat Jul 21, 2007 1:48 am
Painting the underside a PITA?? Thats an understatement Neil,I've done 3/4 of mine,but need to finish it,it's one of those absolulty shit jobs,but worthwhile.
Did it about 3 years ago,and that along with the continual coating of engine oil kept it tip top,now my engine no longer leaks and the old underseal needs replacing (or replaced ) as it's drying out. :cry:
Your making pretty hasty progress I reckon,all hails to you my sahn.
Nelly
Gumbo
Gumbo
Post Mon Jul 23, 2007 9:38 pm
Looks 'O' so familiar - i bet you've got Hammerite all up your fore arms and the classic head butt marks on the for head :lol:
Looking good as always Neil, keep it up and also keep us updated - your starting to slack in your old age :twisted:
P.S. - finished under sealing mine aaaggggggggeeeeessssssss ago :snigger:
"I F**KING LOVE YOU GUMBO"
320Touring
Post Mon Jul 23, 2007 9:42 pm
Nelly wrote:Looks 'O' so familiar - i bet you've got Hammerite all up your fore arms and the classic head butt marks on the for head :lol:
I currently have a letter from the CEO of hammerite saying "thanks for the 50% increase in sales...
Gotta job interview on wed so cant paint before then. Hopefully knock up a pit to drop the engine into this weekend, so I can get all the servicing done and the bay cleaned and painted. then its waxoyl time
Taylor325i
Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
Post Mon Jul 23, 2007 11:25 pm
Looking good Neil. :cool:
Keep up the good work and keep the pics coming. :thumb:
Taylor.
320Touring
Post Mon Jul 23, 2007 11:34 pm
Taylor325i wrote:Looking good Neil. :cool:
Taylor.
Cheers Taylor- cant wait for lump to be tidied up and the stainless bolt set fitted :cool:
320Touring
Post Fri Jul 27, 2007 10:54 pm
Decided to go for a “pimp my rideâ€a paintjob on the underside.....
Firstly, jacked the fooker way up high, leading to some proper “slammedâ€a moments.
Then set to work removing some annoying/useless/in the way bits...
Spanner monkey at work!
The middle Tank Guard- absolutely GUBBED!time to get onto Paul for a new one
Gearbox exhaust mount and the under gearbox tray- Appears one of the heatshields is loose above the front section, so I'll need to get that resolved-should be easy enough with the engine out..
And lastly, to the joy of Hammerite, and the underside of a car- I'd recommend it to anyone with anger management issues-it'll bore you to tears!
munky30
100% Pure Council
Post Sat Jul 28, 2007 12:31 am
Nice job with the hammerite, I should really do that to mine but I would just be sealing rust in so its kinda pointless.
Ps, that 'under gearbox tray' is new to me... can you post a pic of it in place at some point to enlighten me.
320Touring
Post Sat Jul 28, 2007 12:35 am
munky30 wrote:Nice job with the hammerite, I should really do that to mine but I would just be sealing rust in so its kinda pointless.
Cheers!
the car will get a fu'gutty attack with waxoyl next to stop her getting like yours..
As for the under geabox tray, it bolts into the front subby with 2x 10mm bolts, then runs underneath the gearbox almost to the gearbox mounts.
rear of it fits in a slotted channel built into the floor of the car. will pic it for ya when i put her back togther
320Touring
Post Fri Aug 03, 2007 11:01 pm
So Mike and Erik came over today for an m20 dropping session....
First things first-get the engine disconnected and dropped,
Then checked out how bad the rust was at the front
Removed and replaced the Clutch (only friction plate was replaced as the backing plate was not suitable for the flywheel...)
Fitting the new thrust bearing to the gearbox
Pretending for my mum's sake that I'm tidy....
Prettying up the gearbox before refitting with high temp paint
Erik set about the dent in the front panel, and made a good job of reducing the damage
Jesus325iTouring
Frog freak !
Frog freak !
Post Sat Aug 04, 2007 3:54 pm
Sailing along nicely Budda,keep up the good work :D
PS When I waxoyled my Touring it stank for weeks :cry: does the job mind.
Nelly
Gumbo
Gumbo
Post Sat Aug 04, 2007 7:47 pm
Coming along nicley Neil, will you have her at Santapod this year??
320Touring
Post Sat Aug 04, 2007 11:00 pm
Right-legendary progress finally!
Plan is to spray the car completely in primer for the Callander event, so today was the start of preparations..
Stage one- Locate a Norwegian and equip him with a wire brush (this is 78dude)
Then it was sand and treat time
Next up is a bit of construction work-and voila, a spraybooth!
The neighbour on the left thought I was marrying the car, and the one on the right thought the forensics squad were in town
Found a Hungarian Coin stuck in the most improbable place- you can just see it through the brake lines.
Took it out, sanded the area then put the coin back in-kinda a lucky charm...
Then it was down to the “nitty gritty, make her prettyâ€a
Finally getting there
hammoj28
Post Sat Aug 04, 2007 11:03 pm
Looks good neil. While theres no engine you might aswel ut a 2.7 in........ winkeye
24v tech2
BadDave
You need a top coat on there Neil.
No excuses
There's STILL 3 weeks till Callander
Other than that, good job so far
BadDave
Post Sat Aug 04, 2007 11:05 pm
hammoj28 wrote:Looks good neil. While theres no engine you might aswel ut a 2.7 in........ winkeye
You know it makes sense Neil
Gotta be done
Would be RUDE not to
winkeye
320Touring
Post Sat Aug 04, 2007 11:07 pm
Gotta be done
winkeye
now now lads!
as for the topcoat- issue is its only available in 2 pack-needs air fed mask etc :cry:
Rosc0PColtrane
Post Sun Aug 05, 2007 11:47 am
Shouldn't really drive it in primer mate, get that top coat done!!
d1mmy
Boost Junkie
Post Sun Aug 05, 2007 2:42 pm
Great work mate.
The tent (spray booth) reminding me of Beetle Crisis. Loved that Show.
For sale 325i Sport Turbo & 318i (Sport) M50B25
Nelly
Gumbo
Gumbo
Post Sun Aug 05, 2007 5:17 pm
Primer is still porous Neil - puff it over with some lacquer at least before driving it fella or that dreaded worm will return quickly.
320Touring
Post Sun Aug 05, 2007 11:18 pm
Nelly wrote:Primer is still porous Neil - puff it over with some lacquer at least before driving it fella or that dreaded worm will return quickly.
I'm in two minds- "clean rat" look I like :D
2 pack painting in the street :? 8O
still-its a start :D
320Touring
Post Sun Aug 05, 2007 11:19 pm
D1MYY wrote:Great work mate.
Lol d1myy- not in the same league as your turbo's :)
less rust on the Kiev express than on a beetle too :cool:
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Mon Aug 06, 2007 10:59 am
looking good neil!
Demlotcrew
Post Mon Aug 06, 2007 12:30 pm
Good work mate,
But bad idea on painting the gearbox!
Why? Well the paint will act as an insulator and keep the heat in, which will result in a fucked gearbox over time. (not that short of a time, but it will go)
Rosc0PColtrane
Post Mon Aug 06, 2007 1:07 pm
Demlotcrew wrote:Good work mate,
Why? Well the paint will act as an insulator and keep the heat in, which will result in a ****** gearbox over time. (not that short of a time, but it will go)
Surely the effect of a few microns of paint would be nil compared to the casing of the 'box?
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Mon Aug 06, 2007 2:18 pm
Best get some nice gold bling bling paint on there neil! I mean - if it's for the safety of your gearbox who can argue :P
Demlotcrew
Post Mon Aug 06, 2007 2:51 pm
The whole GB acts as a heat sink, soon as you cover it with paint then the heat transfer changes a great deal, look at intercoolers for example. Some oil contamination and the efficiency drops way off.
HTH
320Touring
Post Mon Aug 06, 2007 2:55 pm
HTH
hmm-high temp paint with loads of thinners. we'll see!doubt the b20 could get the box warm enough :wink: :D
but cheers for the warning!
Demlotcrew
Post Mon Aug 06, 2007 10:56 pm
What did the clutch come off? Looks like a gen BMW item but not for a M20?
320Touring
Post Mon Aug 06, 2007 11:25 pm
Demlotcrew wrote:What did the clutch come off? Looks like a gen BMW item but not for a M20?
New clutch or old one? had to use new friction plate and old pressure plate as new one didnt fit flywheel
Demlotcrew
Post Mon Aug 06, 2007 11:34 pm
New clutch, the friction plate is for a twin mass fly, which you dont have! (looking by the old friction plate)
I would not run it like that, serious shock through the trans even with a B20 on the other end could cause all sorts of problems.
320Touring
Post Mon Aug 06, 2007 11:37 pm
hmmm, it does look different, but was sold to me as an m20 clutch.....
Demlotcrew
Post Mon Aug 06, 2007 11:48 pm
Didnt you think this could be a wrong clutch when the pressure plate didnt fit?
I would send it back, why would you pay for a brand new clutch kit and only use half of it?
Tongs ya bass................
320Touring
Post Tue Aug 07, 2007 12:00 am
Demlotcrew wrote:Didnt you think this could be a wrong clutch when the pressure plate didnt fit?
bought it off a zoner!
tongs, ya bas yersel.
At least I aint fitted the gearbox yet.... :D
Demlotcrew
Post Tue Aug 07, 2007 12:06 am
Yeah because you've still to strip off all that paint :eek:
Also get that bonnet latch cable out of the engine bay! Its only two 10mm bolts :x
And if you wanted to, you could pull the servo out too which will give you enough space to tuck the fuse box out of the way and get right into the corners with the gun :D ill be over that car like a tramp eatin chips! so you better get it fixed :P
BIG CHEESE
:teehee:
