touch up scatch on bumper help
Hap
i had a jagged scratch which i have filled in with touch ....however it looks shite. after reading bout detailing its slightly raised, my q is if after plenty of pc or rotary action to "flat " it down will it look better?
ian332isport
All you will really do with a PC or Rotary is polish the top of the raised touch up.Hap wrote:i had a jagged scratch which i have filled in with touch ....however it looks shite. after reading bout detailing its slightly raised, my q is if after plenty of pc or rotary action to "flat " it down will it look better?
You need to wet sand the area with very fine abrasive paper until the surface is level, and then polish it back with the PC/Rotary.
Ian.
Hap
cheers ian thats what i thought may be the answer
Hap
ps it does look crap but wiv wetssand and pc it should defo look better...im thinking maybe i shunt have tried to fill lit in
1an
c76jon
http://www.langka.com/chip-scratch-repa ... c4b6c86978
this stuff is amazing
patience and follow simple instructions amazing results can be achieved
brilliant for stonechips etc
you need to get a really good match on your touch up and you will be amazed
hth
jon
hth
jon
gaszman
- E30 Zone Meets/Events Team
fine wet and dry then spray with satin black did both the front and the back on mine looks the dogs bollxxx now
