318iS engine oil leaks
kevin316i
Post Sat May 07, 2005 7:26 pm
The engine on my new purchase 318iS has a fine coating of oil all over it, no drips in the driveway, but I want to find the root cause and get fixed. What are the usual culprits in the M42 engine that I should check/get replaced?
Thanks,
Kevin.
Demlotcrew
Post Sat May 07, 2005 7:31 pm
front crank seal.
Andrew
kevin316i
Post Sat May 07, 2005 7:41 pm
Thanks Andrew. The car needs a new rad, so I guess it would be appropriate to get this seal done at the same time?
Demlotcrew
Post Sat May 07, 2005 10:15 pm
Yeah that would be a good idea as you will need to take the thermostat out.
Andrew
Post Sun May 08, 2005 12:24 am
Is the front crank seal the same as the front timing chain cover?! if u get me
David318is
Post Sun May 08, 2005 2:13 pm
Yes it is the same one
Don't forget to get new timing cover gaskets and a new crank bolt.
Just done my timing chains and to get the crank bolt loose (244ftlbs) I bought a spare botom pulley from a breakers and welded a length of steel tube to it which rests on the chassis rail to prevent the engine turning
