angels eye problem
snooka
Post Wed Jul 11, 2007 10:20 pm
i've got one angeleye who isn't working for a 100%.. how can i fix tha?
it only gives a little bit of light
guizai
Post Fri Jul 13, 2007 11:22 pm
are those aftermarket angels eyes or did you build them youself? Seems like the light bulb isn't positioned properly to shine through the ring completely. See if the bulb is crooked or something.
snooka
Post Sat Jul 14, 2007 10:22 pm
after market, from 'in-pro' they worked fine in the beginning... i'll take a closer look in the week ;)
blingsta
Boost Junkie
Post Sat Jul 21, 2007 5:27 pm
there are 4 peanut sized bulbs that make these work, same happened to mine a little while back, take the unit apart and change the bulbs, will brighten it up loads...
snooka
Post Mon Jul 23, 2007 11:15 pm
thanx, i'll take a look how to chenge those, cause i didn't knew you van change them, i saw 4 lights bu ye..
THanX :D 8)
