Post
Wed Jul 11, 2007 1:03 pm
I cant see how you would suck the one nearest the door jamb, it is too close to a formed edge and I expect that the metal has passed its elastic limit. Only way to do that is to fill and paint, unless you want to go to the expense of profestional panel recitificaton
The one in the middle of the panel might push out - take your trim off from the inside and see if you can get to it from the inside, push using your thumbs working from the outer part of the damage inwards until it 'pops'. If it doesnt pop then again, its gone past its elastic limit and you are buggered as above.
