hi guys!
lately i've been smelling the exhaust fumes of the cars infront of me. i think my vents are working properly for when i push the yellow button (circulate) i can hear the vents closing.
what could be the problem? could it be that there's an unsealed opening in my firewall where exhaust fumes creep in?
thanks!
AIR CON PROBLEM
- Brianmoooore
Holes in the bulkhead usually result in wet carpets, so if they are dry, I doubt if this is the problem.
Take the large inspection cover off at the rear of the engine bay and visually check the operation of the vent flaps.
thanks for the reply!
no wet carpets for me though!
by the way, the cover draped on my firewall is falling apart and i've noticed that bits of it are spewed off my aircon vents
actually got into my eye once. it could be a tell tale sign that my flap's aren't working
if this is the case, how do i resolve it?
- Brianmoooore
??? You've lost me here!dj888 wrote: the cover draped on my firewall is falling apart and i've noticed that bits of it are spewed off my aircon ventsactually got into my eye once. it could be a tell tale sign that my flap's aren't working
sorry!Brianmoooore wrote: Take the large inspection cover off at the rear of the engine bay and visually check the operation of the vent flaps.
the inspection cover is cracked already and bits or even chunks of it come out of my aircon vents inside the car... hope its clearer
- Brianmoooore
The cover is made of sheet steel. Can't possibly be cracked!
