lexus v8
jaffro
how much trouble would it be guys 2 put a lexus v8 in my e3o. i have the whole car so prob got all the parts. anybody any ideas. thanks
there's somone on here who is well on his way through this conversion.
Problem is I can't remember his screen name and he's based in New Zealand so no chance of popping round for a cup of tea and a look
fuzzy
i think if you need to ask these questions then it will be to much trouble for you personally. if you get a specialist to fit it for you then your looking at a bill for around £2000+ for labour only as you already have the donor car. just a rough guess but they usually end up much much more than you expect.
I have that engine in my soarer by the way
if you need any technical info then check out
www.toyotaimportsforum.co.uk
and
www.lextreme.com - be warned, this site will make you want to strap a turbo to it
maybe a pair of turbos
and
fuzzy
drifty325i is the zoner with it fitted from new zealand.
jaffro
ive swapped a changed a few engines. just never worked on lexus really. prob would be 2 much for me really just be a good project
jaffro
thats what mines in a soarer. hate the car but like the engine.
you on the soarer forums then?
here's mine
http://www.toyotaimportsforum.co.uk/for ... hp?t=12652
I blow hot & cold with mine, miss having something to chuck about, but it is a superb motorway mile muncher
here's mine
fuzzy
if youve changed engines before then you probably would manage.it would just be a case of overcoming problems as they arose and making up your own mounts etc. basic principles would be the same with perhaps a bit of cutting and welding to make it fit.maybe a specialist to do the electrics would be a good idea though.
jaffro
god. mines a shed compared 2 that mate. only had it 4 weeks a i hate it. yours is stunning mate
did you pick yours up cheap then or did you get burned on ebay?
what's actually wrong with the car. i.e. faults etc?
drifty325i
To be honest its not really a hard swap in my opinion at all. You need a front sump 1uz for a start, bellhousing adaptor for a w series gearbox (im using a w55 supra box) the only mission is really the brake booster (im using a mk11 golf booster and nissan navara master cylinder) custom drive shaft to mount to the bmw lsd diff and toyota gearbox. I used the factory drive shaft modified to suit. i could go on and on but it would take me ages lol and im at work
The V8 in action http://www.youtube.com/watch?v=vp5Eaf8xOgM
jaffro
the car was cheep through a freind. the electrics are the main faults it dors drive nice though
jaffro - from what drifty has said above re the sump. you will need to get a sump from a LS400 as the soarer has the rear sump.
Re the gearbox, not sure how common the W55 box is here, think they can be found in the MK4 supra 3.0 N/A manual cars. I believe the R154 box from the MK3 Supra Turbo is a stronger unit, but they are sought after in the MK3 supra community here as many were autos.
Hope that helps
Hope that helps
jaffro
my lexus is auto dont no if they all are? mite buy another e30 for transplant then i can take my time wiv the swap. thanks for the info. how long tou had your soarer?
had the soarer for 18 months.
all V8 soarers are autos, they never made a manual, not sure if there was ever a manual LS400 either.
you have the 2 manual gearbox options outlined above, for low cost, you are best hunting out manual boxes from MK3 supras as the turbo used the R154 but the non-turbo may actually have used the W54 mentioned by Drifty. look on egay or check out http://forum.mkiiisupra.net to see if anyone is busting a car on there.
as also mentioned, you will need to get a bell housing adaptor to mate the manual box to the engine.
a couple of other places to check out for info www.soarercentral.com an aussie soarer forum but there are a few on there who have done the manual conversion now.
also www.v8soarer.com
http://www.v-eight.com/
drifty325i
Yes will need to be from a ls400 or celisor,
the w55 is quite common here but there are also other options like the w57 or w58 they all use the same mounts but have different ratios.
also make sure the gearbox is a rear shifter w series gearbox. again there are 4 types of shifter positions, front,mid,rear and remote. rear is best but remote will work.
the r154 is a stronger unit with slightly better ratios for the highway but in all honesty the w series gearboxs will handle 500hp no probs lol.
all 1uzfe toyotas are factory auto no manuals at all.
jaffro
just spent most of the day driveing the big pig and im definatly going to get another e30 and do the conversion. ill just take my time. thanks again for the info guys
