info about e34s
gra325i
- E30 Zone Meets/Events Team
daveburke114
probably totaly off topic, but im pissed, i had a 530i manual e34 and it was fuckin awsome! get in! whip out that 540 and put it in a 2door E30!
m3ben05
darkchild
Give BMW customer services a call with the chassis number to see if the original nikasil block has been replaced. E34's eat suspension parts for lunch so check all this out. If it hasn't been done, I'd change the gearbox oil. These are allegedly sealed for life but no oil lasts forever. BMW or a gearbox specialist can change this, but these V8's use the equivalent of liquid gold in the gearbox so it's an expensive job. Other than that, enjoy a superb car
whipsey
i'd change the suspension rubbers for poly ones did it on mine
M5pilot
Be careful with poly bushes on E34's, they don't last long unless you specify the black material.
Only use on the upper and lower front control arms + anti roll bars. DO NOT USE ON SUBFRAME!
Get a nice exhaust, it's rude not to amplify the noise of a V8.
Evo-S
Evo-S
maxfield
My dad's is very unreliable only because of some stupid after market immobilizer.
Also has a bad knocking so probably needs new bushes.
And a scratch or dent in every panel, don't you just love spain?
Agree with Sal a nice exhaust will sound awesome on the V8.
Got me a nice '88 535iSE (manual); great car, bags of oomph (as quick/quicker than a 325i) and a lovely exhaust note but the heater's stuck on!
Also I'm getting a rippling/clonking through the steering wheel on rough roads so I'm going to have to take a look at the front suspension soon...
whipsey
i changed both my front control arms on there
Andy335Touring
Dodgy heater valve or may be some thing behind the heater controls has come adrift ?320iSE wrote: but the heater's stuck on!
Checked it out today; it's getting 12V to the connector when the heater controls are anticlockwise (cold), dropping to 0V in the clockwise (hot) setting. I took the heater valve apart, the valves looked reasonably clean, but I noticed that the solenoids don't seem to have any effect on them - they just 'hum' a little when power is applied
