idle speed has always been a problem of mine. it pulsates like a heartbeat varying from .8-1k rpm.
however, just this morning, the moment you start the car, it idles at 3k! Help me! what are the things i should look into? thanks in advance!
HELP! idle is at 3k!
Take off the ICV and give it a blast with some carb/brake cleaner. Make sure the vavle inside is moving freely.
This happened when I left my e30 off the road for a couple of months, it just froze up the vavle inside of the ICV.
SPADGE
If its jammed open then removing the plug isn't going to make any difference.dj888 wrote:thanks for the reply!
however, even if i disconnect the plug that connects to the icv the idle does not change. so, i suspect it has nothing to do with my icv.
320Touring
I would check that the throttle cable is returning to the correct stop when pedal is not pressed.dj888 wrote:idle speed has always been a problem of mine. it pulsates like a heartbeat varying from .8-1k rpm.
sounds like its sticking
checked that as well. no luck!320Touring wrote:I would check that the throttle cable is returning to the correct stop when pedal is not pressed.dj888 wrote:idle speed has always been a problem of mine. it pulsates like a heartbeat varying from .8-1k rpm.
Martinaston
Suspecting it has nothing to do with the ICV and confirming it has nothing to do with the ICV is the difference between fixing it and not fixing it.
There is NO nucleus.
