just wouderd have enyone here changed their 325 from automatic to manual and if so. what was the job like to do as im thinking of giving mine to someone to have ago
eny help on this convertion would be much needed.........cheers
auto to manual
Ant
- Retired Team Member
its not a bad swop
you need the brake and clutch pedals from the manula donor, plus the 2 helper springs and the mastercylinder assy. you dont need to swop the entire pedalbox assy over !
from the engine bay you'll need the master cyl to slave rigid hose( on bulkhead ) and the flexi hose from the n/s inner trans tunnel.
if the Auto is a Switchable, you'll need the manual prop too ( S/Auto has 4 bolt guibo)
there are some electrical tweaks to do, but the mechanicals are an easy enough, if time consuming job.
HTH
HTH
Email FTW
s/auto has a normal 6 bolt guibo, it's the fact the front section is shorter than a manual one by a good few inches. The rear section is the same.
Ant
4 bolts on the EH Simon..... tut tut dude, slipping
Email FTW
