SERIOUSLY UN-PI$$ED OFF!! (Old Skool worked his magic!!)
- KINGOFSNAKE
aye we all need a bit more attention when were older, you dont mind so much when its a ball achingly beautiful beemer
- Brianmoooore
It's very easy to loose the 13mm nuts when changing a touring rear mount. They disappear down into a void, never to be seen again, along with the odd 13mm socket.
I reckon that sometime in the past a nut was lost and left off for a while, and that's when the damage started.
JohnnyThunders
Im scared now, my touring was a bargain and there is some occasional knocking from the rear shocker area. I had been hoping it was the load cover but it could be something like this... I dont want to look tho, ignorance is bliss, besides its pissing it down outside.
JimmyC
- Contact:
Are the Z3 reinforced plates just a standard BMW order part? and does anyone have a part number, could be a good move for the race car
Bad luck BTW, least you noticed it and no further damage/accident happened
Just ordered 4 of the Z3 reinforcement plates from ZimmerBimmer @ Cotswold BMW (thanks Paul
). I'll be fitting (welding) one above and below the turret on each side to make sure it is all nice and secure for a good few years...
When the plates arrive, I will probably take a template and get a batch laser cut for anyone who is interested in reinforcing their rear turrets too?? Paul has given a good price and I am more than happy to pay out to get the car back on the road ASAP, but I can probably get them made a lot cheaper for other members if they are thinkng of doing the same? (as long as that doesn't tread on anyone's toes??)
Thanks again for all the comments and suggestions.
Hopefully be back on the road later this week....
Regards,
Bruce.
Regards,
Bruce.
Farewell E30 ownership!!!!
Part number: 51718413359 (£10.20 each inc VAT, but Paul can do them a bit cheaper)JimmyC wrote:Are the Z3 reinforced plates just a standard BMW order part? and does anyone have a part number, could be a good move for the race car
Jimmy, see my post below yours regarding getting a batch made....
Regards,
Bruce.
- Brianmoooore
This will just be the top mount itself. Very common.JohnnyThunders wrote:Im scared now, my touring was a bargain and there is some occasional knocking from the rear shocker area. I had been hoping it was the load cover but it could be something like this... I dont want to look tho, ignorance is bliss, besides its pissing it down outside.
Replace both of them with E46 cab. top mounts, which are a direct replacement, more durable, and probably cheaper.
Get them from zimmmerbimmer1, our soon to be announced, very own, zone dealer.
steerfromtherear
If it helps calm any specualtion I had a few areas of metal fatigue on my m535i that were equally confusing and annoying. No rust or stress exerted and things snapped clean away. Handbrake through the floor and captive nut for the front seats to bolt to just fell through the floor.
I think it is a slight concern for older BMW owners, especially as it cant be identified anyway like rust can.
Crikey i've never seen that before. Very strange is it passenger side?
I've never had problems with top mounts but i have always used the e46 m3 cab ones, also on super low suspension for the ring piece and the mounts are still in top condition.
I'd say normally you wouldn't need the Z3 plates and that the e46 bush is adequate but in your case Bruce i think it's a good idea!
- Brianmoooore
The only area that E30s have any metal fatigue problems are in the front inner wings on hard driven cars, and the wire that goes to the speedo sensor. This is a total one off, and must have had a cause somewhere along the line.
Used to look after an m535i e28 and it too had the captive seat nuts fatigue away into the box section.steerfromtherear wrote:If it helps calm any specualtion I had a few areas of metal fatigue on my m535i that were equally confusing and annoying. No rust or stress exerted and things snapped clean away. Handbrake through the floor and captive nut for the front seats to bolt to just fell through the floor.
steerfromtherear
Same has happened to James at BeemerRedeemer's m535i iirc.
Must be a common fault, should really post this on a 5 series board lol.
Martinaston
At a guess, uprated anti roll bar and shorter shocksBrianmoooore wrote:The only area that E30s have any metal fatigue problems are in the front inner wings on hard driven cars, and the wire that goes to the speedo sensor. This is a total one off, and must have had a cause somewhere along the line.
There is NO nucleus.
The car has stock ARB's at present. The shocks are H&R ones - the car has the H&R cup kit fitted.Martinaston wrote:At a guess, uprated anti roll bar and shorter shocksBrianmoooore wrote:The only area that E30s have any metal fatigue problems are in the front inner wings on hard driven cars, and the wire that goes to the speedo sensor. This is a total one off, and must have had a cause somewhere along the line.
Regards,
Bruce.
Rosc0PColtrane
I guess when any NDT or inspection is done on the materials used for these cars, not only would 20 years down the line not really be a consideration, but also impossible to test every car that comes off the line. So there is every possiblility that some cars will have fatigued metal in them. They'll slip through the batch testing.
20 years of driving and uprating components may exacorbate the issue and it's just ill-fortune.
Bruce, (O.T) Did Jeremy get hold of you? (The z1 owner). He has a touring too. Knows a lot of people and is a worthwhile connection.
"What does exacerbate mean?"Rosc0PColtrane wrote:20 years of driving and uprating components may exacorbate the issue and it's just ill-fortune.
Not heard anything yet.....but would be great to get in touch with him....especially if he's got a Touring AND a Z1!Rosc0PColtrane wrote:Bruce, (O.T) Did Jeremy get hold of you? (The z1 owner). He has a touring too. Knows a lot of people and is a worthwhile connection.
Cheers,
Bruce.
Rosc0PColtrane
Sorry, spelling error, meant exacerbate; To make more violent, bitter, or severe.
He said he'd call you mate. He was fannying around in London yesterday and was worried about disturbing you. I'll PM you his number if you like.
Thanks for that. Steep learning curve & all that....Simon13 wrote:The shocks will be boge's, as H&R don't make shocks
Got the plates from ZimmerBimmer today (thanks Paul
There isn't enough room on the threads to have a plate top and bottom unless I use nylock nuts instead of spring washers. I'll let Dameon decide how to address this issue....he certainly knows what he is doing!
When I removed the nuts, there were no spring washers underneath (i.e. nothing to stop the nuts coming undone) and both nuts were fairly loosly fitted - maybe the cause of the problem??
I took the liberty of adding spring washers and tightening the nuts on the O/S while I was at it!
I'll update again when I've seen Dameon on Sunday.
Regards,
Bruce.
glad i flicked through this and must say,Bruce very sorry its gone...and no i have seen the mount area within last 18 month,i have done over 6k on it since,never a problem-but will say as good ole Brian mentioned that it did have one stud (top mount)sheared.dont know how long it drove like this with previous owner ,but never made any noise?
this area is very weak however...so all you "i smell a rat,he knew"dont judge me that way...id hardly flog a car to a guy that he had to drive 4-5hrs home in that way...
munky30
- 100% Pure Council
yeah you would, you're a born scammer, scraping a living by flogging potential deathtraps to poor unsuspecting z1 owners.
Its tantamount to attempted murder, you should be locked up and bum raped and hit with sticks and stuff.
Burn him.... BUUUUURRRRN HIIIIIIIM!
Demlotcrew
They dont need washers as the nuts are self locking.
Nice Z3 plates
Nice Z3 plates
ok re phrased, will the welding of that Z3 plate put enough strength back in to that area?
Metal fetigue is a nasty thing as when things are bent back or sorted out it seems to take half the force it did the first time to bend it again.
Simon13 wrote:ok re phrased, will the welding of that Z3 plate put enough strength back in to that area?
Put it this way - a 3mm sandwich of steel welded either side of the fatigued area (6mm all in) 'should' be enough to put the strength back!ZedOne wrote:Simon, thanks again for the Z3 plate part number. I'll be ordering 4 of them first thing tomorrow (one welded above + one welded below each turret)
Just to be safe, Dameon will be handed the car and the plates. What he does with it will be more than enough to ensure all is safe.
Aha....but what you can't see in the original photos is that the nut was just a 'standard' nut - not the flanged type used when I fitted the Z3 plate. (obviously I wasn't expecting you to be able to see this in the first photos....I do understand that your x-ray vision doesn't work on digital photo'sDemlotcrew wrote:They dont need washers as the nuts are self locking.
I still added a spring washer to be on the safe side even though I used some flanged nuts I had in my toolbox
Regards,
Bruce.
andymn
sorry to hear the problems you've been having mate. I think you should point out what you actually got for your money, just for the critics.
Graham has been a good mate for 10 years and you know you're getting a good deal from him. As said previously, he won't sell anything with a fault........it will be fixed regardless of cost.
The thread has gone on about this bad point, what about the good points of the car?
Do you honestly think Graham would put a turbo in it, ( as he was going to do ) if he thought there were any serious problems???
march109
- Contact:
andymn I think everyone is well aware of that, there was another thread where ZedOne listed all the extras he got and how much he loved the car, no one here is blaming gcorky, munkys post I am sure was in jest (as are most of his posts!)
munky30
- 100% Pure Council
yes very much so
And graham would know it if he read it,
otherwise I wouldnt have said it.
(look malc, I can rhyme.. is it too much to ask that you do it just once?!)
munky30
- 100% Pure Council
I agree, I've not known graham long and not actually met him. But from chatting to him on here and msn, and doing a bit of business with him and he is a thoroughly genuine guy. I cant for one second believe he sold it knowing of this problem.
I think its been accepted that he didnt know about it by most if not all of the people that have replied.
Rosc0PColtrane
FFS Bruce wasn't blaming Graham!!! We've established that it's one of those things and we've moved onto a fix, with pics that we can all learn from!!!
