hi
i am getting a strange noise ,its not that loud and sounds like its coming from the top end, it only lasts for about 5 mins during the warm up then you can barely hear it . i have done a recent oil and filter change and also adjusted the tappets . its a 325i 89 .
thanks for any help
strange noise
Grim_Reaper
if its top end it must be the tappets...you say you have done a recent oil change, have you used oil that is too thick/thin for the engine?
also why did you adjust the tappets? were they making noise before?
the oils ok i think, the owner before me had run it on this for for a few years.the tappets were noisy before and when the engine is warm is runs lovley and sounds good. i used the guide from the zone to get the correct settings. i thought that it might be the injectors, is this pos?
Grim_Reaper
what grade oil did you use??? and how recent did you do the change?
march109
- Contact:
3rd thread on this subject in the last fortnight,
You are not alone , 4 other M20 owners have experienced an increase in engine noise after an oil change.
Related Threads:
http://www.e30zone.net/modules.php?name ... ic&t=70949
http://www.e30zone.net/modules.php?name ... hlight=oil
Related Threads:
march109
- Contact:
FYI tapping could still be the tappets (adjusting them may not eliminate the noise completely and new oil ma have worsened the noise), or worn camshaft, or injectors or loose exhaust or intake gasket.
