HI ZONERS, THIS IS MY FIRST TIME ON THE FORUM, I HAVE RECENTLY BOUGHT MY TOURER AND IT JERKS WHILE I AM DRIVIN ON A CONSTANT THROTTLE OPENING, IT ACCELERATES FINE BUT DOES FEEL SLOW COMPARED TO ANOTHER I SOLD RECENTLY. I AM SERVICING IT ON WEDNESDAY AND HAVE BEEN CHECKING OUT THE FORUM LOOKING FOR CLUES AS TO WHY THIS COULD BE HAPPENING. GOING TO ADJUST THE VALVES AS THEY ARE A BIT NOISY, ALSO THERE SEEMS TO BE A BIT OF HUNTING AT IDLE AND THE CAR SEEMS TO SHAKE A BIT WHEN I BELIEVE THESE ENGINES SHOULD BE SILKY SMOOTH. ANY ADVICE WOULD BE GRATEFULL,THANKS GEOFF.
P.S I WILL PUT SOME PICS ON SOON
MY 325TOURER JERKS WHILST DRIVING
I am pretty confident the inlet manifold gaskets are perished.
Identical symptoms to what mine had, jerks when driving on a constant light throttle and hunts up and down the revs at tickover.
get the car running and warmed up, then spray WD40 or carb cleaner around the inlet manifold where it bolts to the side of the head. If the idle smooths out briefly then you've found your problem.
The gaskets are pennies but it's a bit of a fanny of a job, also look to replace the rubber "O" rings which go between the crank case breather pipe and the underside of the inlet manifold. all will become apparent once you get the manifold off.
Worth checking other things too like vacum hoses around the throttle body and also the large black rubber elbow as they can split and let in unmetered air which messes things up
Welcome to the zone
Welcome to the zone
billgatese30
moved it to the tech help forum for you
and as for the problem i would agree with beemerlad
THANKS GUYS,HADNT REALIZED I HAD POSTED IT IN THE WRONG PLACE! STILL LEARNING. WILL TRY YOUR TIPS AFTER IVE SERVICED IT ON WEDNESDAY. GOT QUITE A BIT TO DO, I THINK I HAD A WATERPUMP FAILURE LAST WEEK ON THE WAY HOME FROM WORK, GOT OFF THE MOTORWAY AND THOUGHT SOMEONES CAR IS MAKING A RACKET, TURNED STEREO DOWN, THOUGHT BLOODY HELL ITS MINE! FANBELT WAS SCREECHIN BAD, WHEN I LOOKED IT HAD SNAPPED AND WAS HEAT WELDED TO PULLEY. MANAGED TO GET IT OFF AND FOUND THAT WATERPUMP PULLEY COULD BE MOVED ABOUT, SO ORDERED NEW BITS AND SERVICE ITEMS AT THE SAME TIME. CANT WAIT FOR WEDNESDAY. CAR IS IN GREAT CONDITION, ALPINE WHITE, NO RUST, LOTS OF HISTORY N ONLY108K.billgatese30 wrote:moved it to the tech help forum for you
BEEN ON THE ZONE FOR A FEW WEEKS NOW AND ABSOLUTLY LOVE IT, THANKS FOR THE WELCOME.
P.S GOT ANOTHER 325 TOURER FOR SALE IF ANYONE IS INTERESTED, ZINNOBAR RED
incase you need it, there is an excellent guide here for changing cambelt
click on link, then click on maintenance and then scroll to the bottom for "timing belt change"
http://www.angelfire.com/blues2/bimmer/
yepM7GHR wrote:thanks 4 that, just read it, does the cambelt have to come off to change the waterpump?
i did waterpump on the tech and never took the cambelt off
www.oldskoolfantasy.co.uk
well yes actually it is possible, but you'd be a fool not to change the belt (unless the belt was recently replaced)
no offence intended dazzle
none taken mate
i dont like messing with timing
thats why i didnt do belt at same time
thanks again ror your help, sorry for the dumb question bout having to do the cambelt aswell, i was at work when i read it, was read very quickly!! read it again when i got home and it made a lot more sense. on with the job now and that link is really good, its right bout taking the bonnet off, makes life a lot easier.
I used that guide when changing the belt on my 325 when I had it, having never done a job like that before, it worked fine, just take your time and follow the instructions, I printed it all out so I could follow the pics etc. Remmeber the car in that guide is a US LHD car, so references to driver and passenger side are the other way round
