electric problems
kirils
Sat Jun 23, 2007 6:53 am
I have some electric problems in my e30 320i 1983.
The radio works fine untill i turn on the lights, it stops working it goes on and off like there isn;t enough electricity. The batery is fine and also the alternator is charging good.
My radio is connected to the wire for the emergency blinkers ( cant remember for the english term ) i tryed to put it on the rear window heating and it was the same...
kevin316i
Sat Jun 23, 2007 6:57 am
Is there no dedicted supply for the radio in your car?
tezk
Sat Jun 23, 2007 11:55 am
I'd recomment picking up Part reference: PC2-25-4
from here
With a link here from someone who's fitted one. Did mine as part of the dash replacement and a lot happier with it now.
It will basically replace all the radio wiring behind the dash up to the jack in the passenger footwell and well recommended if your radio wiring has been "modified"..
boxclever1753
Sat Jun 23, 2007 7:33 pm
i bought the blue spot loom this week and will be having a go to fit it tomorrow... the guide in the ICE section is great.
will let you know how i get on!
jcjdavis1
Sat Jun 23, 2007 7:37 pm
Hi I have used the Part tezk recommends and it worked fine,also I think ECP does one.If you look in the styling/ice section and go to page 4,and look for post "wiring in radio" you will find a good write up.HTH Jim
kirils
Sat Jun 23, 2007 11:48 pm
the thing is that the radio worked connected like that perfect for one year, and now is making problems, so it got me thinking that it is something bigger? tomoorow will start loking for the problem
kirils
Sun Jun 24, 2007 5:37 pm
Found the problem it was bad grounding, don't know why this ocured but now is fine :)
