the compression of an engine ?
When I fit a schrick cam will I have to increase the compression ?
Will a cam affect
Turbo-Brown
- Boost Junkie
Yes, the cam will lower the dynamic compression of your engine. I tapped out a big long post on the subject a while ago, perhaps have a search for that.
Ant
- Retired Team Member
100% with Alex, the duration and overlap cost you some cylinder fill ( some is blown out.. ) so long duration requires more static CR, a high lift shorter duration cam will have less of a negative effect on the CR.
Email FTW
ed325i
So how much should I take off the head to bring the CR back up ?
gcorky
- Boost Junkie
ed325i
No, I was going to but he wont give me the full part number, I will take your word that its a 304 and not the 284. I was trying to save a bit of moneygcorky wrote:ed325i wrote:So how much should I take off the head to bring the CR back up ?
did you get that cam * I tried to use text speak but the text speak filter stopped me *?
I will be getting a cat cam.
i wouldn't skimm the head, i can't see a cam effecting the CR so much that it would be detrimental to the performance. I may be wrong of course
reggid
as turbo brown said a cam will lower the dynamic compression which can be detrimental to a standard compression engines torque curve.
