Anyone know what the resistance should be?
Checking HT Leads
CaesarBob
Is there an easy way to test the HT Leads using a multimeter or something else?
'97 E36 B3 3.2 Touring - Alpina-Blau
'15 F32 420d M Sport Coupe - BMW - melbourne-metallic (Sold)
'11 E92 320d M Sport Coupe - BMW-saphirschwarz-metallic (Sold)
'99 E36 328iA SE "Shooting Brake" - BMW-titansilber-metallic (Sold)
'89 E30 325i
'89 E30 325i
Gwynleym10
dunno about checking resistance but if you run the engine its dark you can check for "arcing" thats when a HT lead is split and current is jumping to next lead or to the ground
CaesarBob
I've checked the outside of all the leads and there is no sign of damage to the leads. It just seemed strange that the no.4 lead was different to the others. Maybe it's because it's the longest lead?
'89 E30 325i
'89 E30 325i
Demlotcrew
Dude BMW use quite specialist tools to check the HT and ignition system its very hard for you to do the same without them.
Andrew
Andrew
nwmlarge
if you have any queries surely its simpler just to replace them
if it makes no odds then you have spare set
it will probably benefit anyway.
Russ
Just make sure the engine is running when you remove them! lol
Just kidding!
Just kidding!
318iS became MR2 Turbo became FTO GPX Mivec became Impreza became Rover 620Ti became Honda S2000 (current) became Fiesta 1.25 and 200SX Drift Slag (when the Honda has gone)
CaesarBob
Yeah - thanks for that Russ!
Problem with buying a set that i don't need is it'll will cost me about Ԛ£100 (which i ain't got right now).
Andrew - so your saying it's a BMW only job to test them properly?
Looks like i'm waiting till it actually breaks before replacing them.
'89 E30 325i
'89 E30 325i
Ant
- Retired Team Member
Conti test them Bob M8
compare all the leads and see what results you get, obviously they should be within 10% of each other
HTH ish
Demlot is spot on about the tool BTW,
HTH ish
nwmlarge
jesus what the hell are you running if the ht leads cost Ԛ£100 i just bought a set for my 316 for under Ԛ£15
CaesarBob
I've got a 318iS so the plugs are all inbetween the cam shafts down a big hole. The leads have massive great insulators on the end. Guess that's why they're so expensive!
Ant - as long as they're all about the same it should be ok? The engine runs with no obvious issues so i'm guessing they ain't that bad.
'89 E30 325i
'89 E30 325i
nwmlarge
fair enough
