touring headlining
Cloggy Saint
HairyScreech
iirc its lining/foam/hardboardlikestuff. as it isnt the same as a saloon one and requires more support to keep it up.
Cloggy Saint
- zimmerbimmer1
- BMW Parts Meister
No it is not tucked under screen it is clipped at the front be careful if you pull down to far it will crack or break
Cloggy Saint
Cloggy Saint
Would a black sport headlining from a saloon fit a touring then?oze30 wrote:In that case.. now would be a good time to upgrade to a black sport headlining. The sunroof motorbracket needs to be dropped to get the cable past ( pending if it's been done properly when it was replaced)
- Brianmoooore
Think you'll find there's a big hole at the back!less2303 wrote:Would a black sport headlining from a saloon fit a touring then?oze30 wrote:In that case.. now would be a good time to upgrade to a black sport headlining. The sunroof motorbracket needs to be dropped to get the cable past ( pending if it's been done properly when it was replaced)
The sunroof console.. not the dodgy flimsy black thing!!!Brianmoooore wrote:Think you'll find there's a big hole at the back!less2303 wrote:Would a black sport headlining from a saloon fit a touring then?oze30 wrote:In that case.. now would be a good time to upgrade to a black sport headlining. The sunroof motorbracket needs to be dropped to get the cable past ( pending if it's been done properly when it was replaced)
The good news is that the black factory headliner is still available for the Touring. The bad news (if you have a sunroof) is that the sunroof panel is NLA. Argh! Ask me how I found out. ...And before you get all clever and think you can just order the black panel from an E30 M3, the fabric is not a match. Double-argh!
I just ended up taking my car to an upholstery shop and they stripped and re-skinned the whole thing in swanky black cloth. Not an exact match to the factory item, but it looks great and is MUCH more affordable.
-KDS in Vancouver ('88 325i Touring)
SPADGE
Col is refering to the black console thing that the visors attach through not the headlining itself.
All the roof aerials i have seen are held on with the 8mm nut which is on the outside under the plastic cover.
Simon
- Contact:
The black visor panel is a straight swop, and makes a great improvement to the crappy touring one. Did mine when I first bought it.
E30's on the continent do have different aerials, my M3 came with one when I bought it, but the end was snapped so I bought a new standard one.
You can see the aerial on Playos car in this pic, towards the rear...
Hi
My headlining on my touring is also drooping at the back and is a crappy cream colour, I am thinking of removing it and putting glue on the saggy bits, then giving it a coat of black spray, anybody done this before ????
Cloggy Saint
There's a similar thread going on here
I know people who have said a headlining can be painted but i've never seen pictures. My headling is currently held up by a load of drawing pins. It looks great
