Power Loss
eko
Old timer
Post Sun May 01, 2005 9:45 pm
my 316i is losing power :o
when its cold its not too bad,but as soon as it starts to warm up it goes really flat!
I have changed the inlet manifold gaskets as one was leaking and replaced the AFM with a tested 2nd hand one.
It runs very well,idling at around 700rpm,starts up 1st time everytime and is surprisingly very good on fuel!
Power loss i can only describe as-when i put my foot down in any gear not a lot seems to happen,but if i gradually back off the throttle it tries to pick up???
Any ideas guys?
LOOPYLEE1965
Post Sun May 01, 2005 10:01 pm
i had exactly the same problem with my 316 (was 1800 carb though) and found out that the ignition timing was too far advanced if it pinks when you accelerate that normally gives it away but if i were you id get the timing checked as it can causepre ignition and over heating hope this helps dude
eko
Old timer
Post Sun May 01, 2005 10:09 pm
Cheers mate,but mine M40 1.6i engine,so timing cant be adjusted?
LOOPYLEE1965
Post Sun May 01, 2005 10:42 pm
soz m8 know nowt about them but i would firstly look at all your intake pipes etc to see if you are sucking any air in ? sorry cant be any more help than that but someone on here will give you advise seem a good and very helpful bunch on here :wink:
